Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jul 2011
    Posts
    3
    35 massey
    Default 67 35 massey help
    new here and right away looking for help. I have a 35 massey diesel thet has been in the family since new. not many hours on it. all original yet. it started leaking large amounts of oil from the little hole in the tach drive plate. wghat happened and how do I fix it.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Super Member Farmwithjunk's Avatar
    Join Date
    Aug 2005
    Posts
    7,514
    Mt Washington, Kentucky
    Where do I begin.....
    Default Re: 67 35 massey help
    Quote Originally Posted by freakshow12 View Post
    OK....From the top....
    It is NOT a 1967 35. Last 35's were built in 1964, prior to introduction of the 135.
    Now, the leak....There's a seal in that plate. You'll need to remove two bolts (plus the cable) to access it. Massey Ferguson/AGCO dealer will have it, as it was common to all Perkins 3-cylinders for over 50 years they were installed in MF tractors. Simple change out that should be easily done by any shade tree mechanic.
    A temporary fix that'll get you out of the field is to clean up all the leaking oil. Then you'll see a small vent hole below the cable connector. Fill that with Permatex (or similar gasket sealer) let dry, and go. DO NOT depend on that as a long term fix. It will let you down at the worst possible moment. BTDT.
    There are three kinds of men;
    1.) The ones that learn by reading
    2.) The few who learn by observation
    3.) The rest of them have to pee on the electric fence for themselves.
  4. #3
    New Member
    Join Date
    Jul 2011
    Posts
    3
    35 massey
    thanks. my bad on the year. my dad bought it from his stepdad years ago. I am a car guy so these are new to me. I will look at the plate and see what year it is for sure. we got the plate bolts out but cannot release the cable. how does it come out?
  5. #4
    Join Date
    Aug 2005
    Posts
    7,514
    There's a threaded coupler on the end of the cable, OUTSIDE of the plate. First unscrew that coupler. Quite often, the tach cable will "wallow" out a bit on the end and sorta key itself into the fitting on the end of the camshaft. you may have to remove the opposite end of the cable (at the tach) and GENTLY use a pair of pliers to rotate the cable too and fro while someone pulls on the cable at the engine end, until it releases. It SHOULD pull right out. Old parts can sometimes be a little stubborn.
  6. #5
    New Member
    Join Date
    Jul 2011
    Posts
    3
    35 massey
    Thanks so much. we will try that.
Similar Threads
  1. massey ferguson 1635
    By chrisdvorak in forum Buying/Pricing/Comparisons
    Last Post: 07-12-2009, 04:55 PM
  2. massey 35 power steering leak help
    By massey 40 in forum Massey Ferguson Owning/Operating
    Last Post: 05-04-2009, 06:20 PM
  3. Help identify my fathers Massey
    By Willl in forum Massey Ferguson Owning/Operating
    Last Post: 10-23-2006, 02:15 AM
  4. No Deal on PINK Massey
    By hunterridgefarm in forum Related Topics
    Last Post: 10-13-2006, 10:24 AM
  5. Question on BX series loaders
    By jim_wilson in forum Kubota Owning/Operating
    Last Post: 06-30-2004, 03:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
