Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Nov 2011
    Posts
    4
    mf 135
    Default mf 135 ???timing and oil
    I have an 80s model 135,,,can some one tell me how to set the ign. timing how to fill the hydralic and the transmission,,,,,,,,,,,,also i cant seem to shut off the pto??? and what areall the levers are for??
  2. #2
    Platinum Member soulasphil's Avatar
    Join Date
    Nov 2008
    Posts
    504
    France
    JD 3520 powerreverser
    Default Re: mf 135 ???timing and oil
    Hello, you have a very nice tractor.
    Pic one shows the 2 gear levers, the long one for three gears forward and one reverse, the shorter one to switch between high and low gears.
    Pic 2 has a red arrow pointing towards the lever for the PTO, engine speed, wheels speed or stopped.
    Pic 3 shows the 2 levers working the 3 pt hitch.
    Hope you have some seat time soon.
    Attached Thumbnails Attached Thumbnails mf 135 ???timing and oil-dscf0135-copier-jpg   mf 135 ???timing and oil-dscf1076b-r-olution-de-l   mf 135 ???timing and oil-dscf0143-copier-jpg   mf 135 ???timing and oil-dscf0141-copier-jpg
    3520 PR
  3. #3
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,023
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    In pic 1, sitting in the seat, if you look beside the left shifter, you will see a plug, that is how you fill the teams. Only 1 fill hole as it is a common reservoir.
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
Similar Threads
  1. how come my oil is green?
    By msjanket in forum Iseki
    Last Post: 04-06-2012, 01:45 AM
  2. oil choices, budget.. etc..
    By Soundguy in forum Trailers & Transportation
    Last Post: 09-13-2011, 10:20 PM
  3. 135 MASSEY FERGUSON AG3-152 Oil Leaks
    By stanmcleod in forum Ag Tractors & Machinery
    Last Post: 11-11-2010, 10:35 AM
  4. How efficient is synthetic motor oil to make.
    By slowrev in forum Oil, Fuel & Lubricants
    Last Post: 10-29-2010, 10:07 PM
  5. MF 135 Electrical Problem - need suggestions
    By Dark Ridge in forum Parts/Repairs
    Last Post: 06-04-2010, 01:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
