Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    3,116
    Tennessee Vols Country
    My tractor is an old M... F... and red too.
    Default Re: Massey Ferguson 135 Hydraulics Success and Laughable Pics
    Well, I think you found the 102nd use for the little giant ladder. Congratulations for your discovery and willingness to take on the unknown. Good job. So far.
    Retired and enjoying life and my grandchildren -robert
    "life is too short.. eat your cake first" ~rpk
    My 1965 MF 135 Z145 Refurbish project
    About ME
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    Local dealer quoted $100 to pick up and $100 for an estimate. Everything was too close to working so I went for it. And apparently a well calculated jiggle was all that it needed. If I can manage to get it back together I may be in business.
  4. #13
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,508
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    personally i'd use diesel... cheaper.. and you can filter it thru a tshirt and run it back thru a garden sprayer and keep hosing the sump out with a drain pan catching the drainings and junk.
    wd-40? why.. got some stickers on glass to remove?
    brake / carb cleaner? Ok.. but harsh solvents. I've seen excessive use damage some types of orings and gaskets.
    I've yet to see diesel damage a seal, gasket or oring, other than a natural rubber ring, or one rated for potable water use...
    your machine.. your call.
  5. #14
    Platinum Member Mike476's Avatar
    Join Date
    Jun 2010
    Posts
    862
    Annapolis Valley, Nova Scotia
    MF 135 Z134 Continental, MF 1660 Cab
    WD40 will work to clean the dried on grease from years of setting there, as far as flushing it, spend the time and clean every crevice by hand, no need for diesel or anything else. Diesel is as much of a contaminant to hyd oil as anything else, spend the time.
    Change your fluid, without question.
  6. #15
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    Now, does it need a very light grease coating after the scrub treatment? Or will there still be plenty and don't need to add mor to the situation?
  7. #16
    Join Date
    Mar 2002
    Posts
    42,508
    Central florida
    Quote Originally Posted by Mike476 View Post
    on an old antique like that one.. and considering what the oil looked like before, and with the op's questioning changining it....
    a diesel 'residue' wouldn't hurt anything! Besides.. you don't like diesel residue.. pump some alcohol thru a sparayer and then let it drip then flash.. or naptha.. etc..
    i'd rather had a lil diesel in my sump than a lil water.. or a little dirt!
    a well known tractor manufacturer used to reccomend thinning their rear end oil/hyd fluid with a lil fuel oil every winter..
    these oldies are tough!
    the residue that might be left on the inside of the castings might amount to a few ounces at most.
    if that machine were so brittle that a few ounces of diesel, ANYWHERE, made a difference to it.. it wouldn't still be in operation. between the old ford N, and the mf 35/135.. they are some of the most durable machines aver made.. look how many are still running.. and how well they hold their value.
    that said.. to the OP.. do whatever you want to do. don't mind my comments.. I'm just elling you what I do and have done on my fleet of antiques i refurbished.. that all work and run.. and sem to like diesel flushing vs dirty sumps
  8. #17
    Join Date
    Jun 2010
    Posts
    862
    Having the same tractor and having cleaned years of over-greasing the lift arms from the case of mine, I know no amount of flushing cleans it to the point that it eliminates having to get in there and clean by hand, so why not just get to it.
    A little bit of diesel won't hurt, but you'd be surprised what hides in the cavities of a 135 case, I was when I did mine.
    To the OP, after cleaning everything up I did take the opportunity to grease the lift arm points, and clean off the excess before installing the cover.
  9. #18
    Banned
    Join Date
    Dec 2011
    Posts
    1,129
    L5450
    Default
    Mine looked a lot like yours when I first removed the top cover, had no idea excess grease entered the casing and contaminated the oil.
    How is the grease getting in there?
  10. #19
    Join Date
    Jun 2010
    Posts
    862
    When you grease the lift arms excess grease pushed out of the bearings can fall into the case. You can see the grease that's made it's way through the bearings and into the interior of the lift cover.
  11. #20
    Super Member
    Join Date
    Dec 2008
    Posts
    5,399
    North Carolina
    Kubota BX2200
    Thanks for all the great pictures in this thread.
    Folks running Chinese tractors have major cleanup to do on their fluid spaces, and most opt for kerosene. It is thought to have slightly higher volatiles than the diesel, but I doubt it matters much. We generally drain and then refill with kerosene, and operate the unit with no load for a few minutes, and put it through it's paces...drain, and depending on what we see, do it again with filtered kerosene or new. It is important to remember that kerosene is not a great lubricant, so you don't want to do just a whole lot with kerosene in the unit.
    In YOUR case, I'd forgo the running, since you seem to have direct access. I have a solvent vat with a little pump. I'd be tempted to pull the legs off mine and put it under the tractor's drain hole, and extend my hose length, and go to town on it.
    Which is bigger?: a) $100 per month since the Big Bang or b) the US National Debt.
Similar Threads
  1. Loader Massey Ferguson 135 Hydraulics Question
    By chooka in forum Massey Ferguson Classic/Vintage
    Last Post: 11-05-2011, 05:05 PM
  2. MAssey Ferguson 135
    By AngelaGay in forum Parts/Repairs
    Last Post: 08-03-2009, 01:19 PM
  3. Massey Ferguson 135 UK
    By van1 in forum Massey Ferguson Classic/Vintage
    Last Post: 06-14-2006, 08:07 PM
  4. Massey Ferguson 135?
    By DmaxEter in forum Massey Ferguson Classic/Vintage
    Last Post: 08-15-2005, 01:00 AM
  5. Massey Ferguson 135
    By SCDolphin in forum Massey Ferguson Classic/Vintage
    Last Post: 08-03-2005, 08:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
