Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Wales
    MF135
    Default Stand or stack pipe below hydraulic lift cover
    Hello.
    I'd welcome some advise please.
    I have just removed the hydraulic lift cover in order to fit a diverter valve.
    To my horror, the stand (stack) pipe below the cover slipped back into the void below.
    I guess this has happened to other folks too.
    What is the best way of retrieving it.
    Thanks in advance.
    Ian M.
  2. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    2,859
    Tennessee Vols Country
    My tractor is an old M... F... and red too.
    Default
    Quote Originally Posted by greenegg View Post
    Hello.
    Thanks in advance.
    Ian M.
    If you can't reach in and feel around for it, then it might be a good time for a hydro oil change so you can find it. Just remember to have plenty of buckets. You didn't mention what type of tractor your working on. My 135 holds around 8 gallons of hydro oil.
    Sent from my iPad iOS 6.01 - TNB v1.6
    Retired and enjoying life and my grandchildren -robert
    "life is too short.. eat your cake first" ~rpk
    My 1965 MF 135 Z145 Refurbish project
    About ME
  3. #3
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Stand or stack pipe below hydraulic lift cover
    i'd agree... a magnet on a stick or hand fishing..
  4. #4
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Wales
    MF135
    Thanks for the replies. It is a MF 135 built in 1965. Firstly I'll try with a magnet.
    If the magnet fails I'm thinking of draining some oil off and then trying to go in behind the lift speed adjustment lever. Is that correct "Kid"?
    The oil is very new!
    Thanks again Ian
  5. #5
    Join Date
    Apr 2012
    Posts
    2,859
    Default
    Thanks again Ian
    If it's new oil, then use clean buckets. Pop over to TSC or Wallyworld and get you a couple of new five gallon plastic buckets and your good to go. Good luck.
    About ME
  6. #6
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    or trash can liners in older buckets.
    BTDT
    I'm cheap.. er frugal..
    clean the underside and drain plug very well.
    when re pouring.. won't hurt to pour thru a paint filter. may get some gunk that HAD been n the sump.. etc..
    wifes old nylones work too..
  7. #7
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Wales
    MF135
    Thanks everyone.
    I have drained down the oil into clean buckets.
    I have removed the lift speed adjustment lever, complete with draft response cam and cover.
    I found and replaced the stand pipe with new O rings.
    So far so good.
    My final concern is replacing the lift speed adjiustment lever.
    Please could someone advise me on where and how the cranked end of the draft resonse cam is located?
    Plus any hints on how to make sure I've done the job properly.
    Thanks
    Ian M
  8. #8
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    isn't there an I&T manual for that tractor.. shgould have all that in exploded diagrams.
    i know they have them for ford, ferguson, AC, case and JD....
  9. #9
    Join Date
    Apr 2012
    Posts
    2,859
    Are you talking about the draft control response
    About ME
  10. #10
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Wales
    MF135
    Hi Soundguy and Kid.
    Please be patient with me. I'm a geriatric former UK school teacher playing at being an engineer!
    The picture shows the bit I'm talking about.
    I bought a "shop manual" when I acquired the tractor and I'm using the terms used in the book.
    Simply where does part 6 in the diagram go and what is the easiest way of fitting it!Stand or stack pipe below hydraulic lift cover-tractor005.jpg
    Thanks. This site is much more helpful than the manual.
    Ian
Similar Threads
  1. MF 135 Hydraulic Lift Cover Help
    By greenegg in forum Parts/Repairs
    Last Post: 01-08-2013, 12:35 PM
  2. Replies: 22
    Last Post: 03-20-2012, 11:36 PM
  3. 3-Point Hitch Lift cover plug
    By 165masseyky in forum Massey Ferguson Owning/Operating
    Last Post: 11-07-2011, 09:17 PM
  4. Exhaust pipe rain cover
    By TomG in forum Ag Tractors & Machinery
    Last Post: 06-06-2011, 09:32 AM
  5. Stand for Post Hole Digger made from Pipe
    By DocHeb in forum Build-It Yourself
    Last Post: 05-02-2003, 03:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
