Results 1 to 7 of 7
02-10-2013, 03:52 PM #1New Member
- Join Date
- Feb 2013
- Posts
- 7
- Location
- Hoosick New York
- Tractor
- MF 40B
MF 40B Help Please
Hello. I am new to the forum as well as the proud owner of a MF40B! I got her last week.
I have a few questions if everybody wouldn't mind?
The first is, I cannot for the life of me, find where you would check and add power steering fluid. I hear it
's near the front of the motor but I can't seem to find it. Btw, it's a Perkins deisel with instant reverse. Also, do you use regular ATF fluid for the power steering?
One other thing, I see a filter on the left side of engine(if looking at it from the front of the machine)that looks like a regular automotive filter. Would that be it and the only one for engine oil? I want to get the oil and filter changed and was going to use Rotella 15w 40w dino oil. I was thinking maybe Rotella synthetic 5w 40w but not sure if I should.
Thanks people! Dan
02-11-2013, 12:40 PM #2Veteran Member
- Join Date
- Feb 2008
- Posts
- 1,805
- Location
- Western Montana
- Tractor
- New Holland TD95D, Ford 4610 & Ferguson TO-30
Re: MF 40B Help Please
Pictures of the items in queston would help for those of us who are not familiar with your specific machine.
02-11-2013, 01:35 PM #3New Member
- Join Date
- Feb 2013
- Posts
- 7
- Location
- Hoosick New York
- Tractor
- MF 40B
Yes! I will get some pics up. Thanks Jerry!
02-14-2013, 05:17 PM #4New Member
- Join Date
- Apr 2010
- Posts
- 2
The power steering fluid is added through the Steering pump, its gear driven on the front of the engine, reservoir has a pipe plug in the side of it. remove the plug and fluid level is bottom of the plug. Sometimes they can be a real pain to get all the air bled out. replace the plug, leave the kill pull out, turn the engine over and turn the steering wheel from lock to lock 3 times, remove the plug and allow the air to escape, top fluid back off and repeat. usually takes about 3 times to get all air out. You can tun DEXRON II in it or an AW 32 viscosity, the 32 will have a tendency to aerate an foam a bit more than the DEXRON II. The filter that you refer to is the engine oil filter.
02-17-2013, 11:30 AM #5New Member
- Join Date
- Feb 2013
- Posts
- 7
- Location
- Hoosick New York
- Tractor
- MF 40B
Cool. Thank you for the help!
02-20-2013, 12:54 AM #6Elite Member
- Join Date
- Apr 2008
- Posts
- 2,797
- Location
- Tractor
Nice tractor!
02-20-2013, 07:33 AM #7New Member
- Join Date
- Feb 2013
- Posts
- 7
- Location
- Hoosick New York
- Tractor
- MF 40B
Thank you!
Similar Threads
40B Ind. Tractor w/bachoe. NEED ROTARY SWING CLYLINDER ADVISE / HELP
By Ohming in forum Massey Ferguson Owning/OperatingReplies: 0Last Post: 02-01-2011, 01:41 PM -
1979 Massey Ferguson 40b backhoe
By yanmars in forum Massey Ferguson Buying/PricingReplies: 2Last Post: 02-16-2010, 04:35 PM -
40B
By hepnerj in forum Massey Ferguson Owning/OperatingReplies: 0Last Post: 10-29-2009, 09:19 AM
