Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    11
    southwest VA
    Ferguson TO-30
    Default new (to me) 1954 TO-30
    My first tractor. Found it locally on Craigslist. Couple pics attached from the Craigslist post. Previous owner delivered it for free and I already started using the blade to work on my driveway.
    Attached Thumbnails Attached Thumbnails new (to me) 1954 TO-30-30_1.jpg   new (to me) 1954 TO-30-30_2.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    3,119
    Tennessee Vols Country
    My tractor is an old M... F... and red too.
    Default Re: new (to me) 1954 TO-30
    Quote Originally Posted by dbotos View Post
    Ann another satisfied Craigslist buyer. I too bought mine off CL. Yes I'd be proud of that classic too. Take care. -robert
    Retired and enjoying life and my grandchildren -robert
    "life is too short.. eat your cake first" ~rpk
    My 1965 MF 135 Z145 Refurbish project
    About ME
  4. #3
    New Member
    Join Date
    Feb 2013
    Posts
    11
    southwest VA
    Ferguson TO-30
    Cool.
    Here's the first thing I'm making for it. Drawbar-mounted hitch adapter so I can move around all the other stuff in my driveway. Gotta make a Harbor Freight run tomorrow to get a piece of hitch receiver tubing. Got the drawbar already from Tractor Supply and picked up the bolts, washers, and nuts when I was at Lowe's today.
    Attached Thumbnails Attached Thumbnails new (to me) 1954 TO-30-drawbar_mount_hitch_on_drawbar.png
  5. #4
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    you can get plenty of work out of that machine!
  6. #5
    New Member
    Join Date
    Feb 2013
    Posts
    11
    southwest VA
    Ferguson TO-30
    I hope to. I've also got one of these Swisher box scrapers with teeth that I had bought for my ATV that I'd like to try with the tractor too. I got a good deal on it as a scratch-and-dent on eBay. I think it had a few little chips in the paint and one bent corner that I straightened with a crescent wrench. It's only 4' wide, but it's got the teeth, which should come in handy on the driveway. Should be able drill a couple holes in some 2" box tubing to mate it up to the hitch adapter.
    Attached Thumbnails Attached Thumbnails new (to me) 1954 TO-30-swisher_box_scraper_with_teeth_line_drawing.png
  7. #6
    Gold Member
    Join Date
    Aug 2008
    Posts
    364
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    dbotos, do a search of my name and look at my posting to another hitch builder. Lots of ideas for that hitch. They are basically what you are already thinking, use the hitch and slide in a piece of tubing and build/adapt whatever you want from there. The 140 Farmall had a 1 point "fast hitch". This can be used as a 1 point reciever hitch. Same idea but using what we can get our hands on easiest.
    I see you already have the drawbar and I have one built like that too, works great. Most car dealers take off the heavy towing hitches from their trade in vehicles. They don't want the new buyer to realize it was used for towing, decreases price. So if you know a car dealer lots of times they have lots of reciever hitches laying behind the shop from taking them off. You've already got the reciever tube mounted on a piece of tubing mounting to the frame. Cut it off the desired width, mount your pins, build the upright going to the top link. I use a mobile home spring hanger axle bracket on top of my upright to connect the top link. Could buy them for 1.00 or so and it fits the top of the tubing perfect, just have to drill the hole out bigger. When you drill it bigger the hole gets sort of close to the outside, closer than it would if I drilled it from scratch, but I have several already out in the field working and it hasn't given any of us a problem yet. It saves having to build the plates and drill them, ready made part basically.
    There is lots you can do with that hitch, you're basically just getting started when you build it.
    modify, adjust and improvise....a country boy can survive
  8. #7
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,797
    I'd be very careful if you use the Swisher box scraper with your tractor because it's probably not strong enough to take the kind of stresses a tractor like the TO-30 can generate. BTW: Nice looking tractor!
  9. #8
    New Member
    Join Date
    Feb 2013
    Posts
    11
    southwest VA
    Ferguson TO-30
    6011Artist - found that other post - lots of good ideas in there:
    http://www.tractorbynet.com/forums/b...ler-mover.html
    MasseyWV - it's fairly heavy-duty for an ATV implement, but I'll be gentle with it.
  10. #9
    Join Date
    Mar 2002
    Posts
    42,524
    Central florida
    tractors make pretzles out of lawnmower and atv implements.
    be doubly carefull.
Similar Threads
  1. 1954 Jubilee
    By GinFarm in forum Buying/Pricing/Comparisons
    Last Post: 12-03-2011, 10:15 AM
  2. Ford 650 (1954) - need pricing
    By bvalley69 in forum Buying/Pricing/Comparisons
    Last Post: 02-26-2008, 01:48 PM
  3. 1954 NAA - Again Pulley
    By Ortis in forum General Vintage Tractors
    Last Post: 10-12-2005, 07:33 AM
  4. 1954 NAA Overheating - Maybe
    Last Post: 05-05-2005, 10:47 PM
  5. My 1954 Farmall 200
    By GreenRules in forum Farmall Vintage Tractors
    Last Post: 03-26-2004, 09:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
