Page 10 of 17 FirstFirst ... 78910111213 ... LastLast
Results 91 to 100 of 163
  1. #91
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default Re: '73 MF135 Perkins diesel AD3.152 help
    Quote Originally Posted by murphy1244 View Post
    Yes a 1967 diesel, just has a starter switch, no preheat also runs a ammeter. My regulator is bad, I sometimes charge and then poof no charge. So I could replace the Reg or just change the whole thing out. What you guy's think?
    If it where me, I'd replace them both. The genny has to be serviced with brushes over time. The VR has to be replaced. Replacing both is a no gimmy. I beleive I read somewhere a while back that MasseyVW was going to use an alternator after he tooted his rebuilt genny. It's just more reliable and you can add more electrical load with a Delco 10SI. I bought an alt bracket cheap enough off ebay. Used my existing genny adjuster and modified it for the alt. Most owners when thier genny plays out replaces with a better charging system. That's just my opinion. -robert
  2. #92
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by The kid View Post
    But if I go with the 10si route, I don't need the stock VR right?
    Murph
  3. #93
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Exactly. But you don't have to remove it if you want to use the terminals as a tie point. Just take it out of circuit. That's what alot do. I have a small terminal strip on the back of my battery tray. But if I had left the VR they I could have used the terminals as a junction point. I removed it so as to not confuse a future owner. In fact some use a working VR with an alternator which doesn't make sense. I guess they didn't want to rewire anything. The way i see it. If your going to update the charging circuit, update the WHOLE circuit as in rewiring. My genny in my opinion was on it's last leg. The voltage would bounce on and off. It looked weird at night with the headlights on. Probably something loose. But already recided to upgrade because the genny didn't have a tachdrive on it, when it should have. Soo you've read the rest of the story.
  4. #94
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Mine bounces too, I thought the VR was bad you think its the alt?
    Murph
  5. #95
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    The stock voltage regulator isn't required because the 10SI alternator is internally regulated.
  6. #96
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Murf, the stock VR's are nototious of needing regular maintenance. Just like points on a gasser. By switching over to an alternator a wire connected to your oil pressure switch will excite the alternator to charge. It also cuts voltage off the alternator so an idiot light is not needed.
    You can tell if your alt is charging by the amp gauge. You'll spend more time mounting the alternator than actually wiring it. It's that simple. You can buy a alt mounting kit on ebay or your local dealer. I have later found using some barrel spacers you can reuse the genny long bolt with spacers to mount the alt to the firewall. I took the tightening bracket and flatened it and ground out a small notch to not interfere with the governor rod to as to not interfere. It may be different on a diesel.
    My alternator fits nicely inside the sheet metal. That is because I measured for a new belt. The original would have hung out futher. I've seem a where few they hang outside the sheet metal quite a bit. One can also give the alt a shot of paint to match the rest it so wanted. I wrap all my wiring double. First with plastic electrical tape and finish with friction. Friction tape seems to seal better and doesn't come undone and more like factory. Anytime you can keep UV off the wire surface it will last longer. I learned this after working in the elctrical power industry for over 35 years. Work I've done 20 years ago in constant exposure to sunlight is still in good shape only because a quality tape job covering the wires.
    Have you ever noticed exposed wires, where the insolation will just crumble in your hand. Tape prevents that. If you take your time and do a good neat job the first time. You will never have to do it again. Not for a long long time.
  7. #97
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    thanks kid
    Murph
  8. #98
    Bronze Member zslnk's Avatar
    Join Date
    Aug 2012
    Posts
    82
    ON, Canada
    MF 135
    Default
    Some tractors had an alternator with an external regulator. Delco 10DN. Mine was born with this configuration and I simply replaced the external regulator with a solid state version that looks the same and plugs right in. It was less than $25.
    It regulates like a modern alternator with solid state internal regulation but looks stock.
  9. #99
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,670
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    DaButcher,
    Thanks for that labeled picture. It could help me in the future.
  10. #100
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Quote Originally Posted by zslnk View Post
    Don't tease, give us a part# and a photo.
    Murph
Similar Threads
  1. Perkins AD3-152 most common oil leaks?
    By Elkins45 in forum Parts/Repairs
    Last Post: 04-20-2013, 03:34 AM
  2. Replies: 6
    Last Post: 12-05-2012, 05:58 PM
  3. MF135 Perkins 2.152 motor
    By Anonymous Poster in forum Parts/Repairs
    Last Post: 07-12-2012, 01:56 PM
  4. Oil & Fuel perkins ad3 152
    By max kay in forum Owning/Operating
    Last Post: 07-29-2011, 09:38 PM
  5. Perkins AD3-152 Question
    By MichaelE in forum Massey Ferguson Owning/Operating
    Last Post: 11-11-2006, 10:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
