Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Silver Member DaButcher's Avatar
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Default Re: Massey Ferguson 135 Rebuild Journey (diesel)
    I took my injectors to the local MF shop and had them pop tested and reset for 1/2 hr of shop labor, they also checked the one new one I needed because the mechanic there said sometimes out of the box the pressure can be set wrong.
    Quote Originally Posted by Rivendale View Post
    Perfect. The picture you posted was just what I needed. I got them all out and the cyl. head is OFF!
  2. #22
    Member
    Join Date
    Nov 2011
    Posts
    37
    Central KY
    Massey Ferguson 135
    Quote Originally Posted by DaButcher View Post
    Good tip. Where did you buy the new injector? I'd like to know in case I have to go that route.
    I am going to take them in and get them worked. I know nothing about injectors and they had plenty of crud on them. That's all I know.
  3. #23
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Got the injector from the same MF dealer that tested the injectors, they source from several places including Sparex and Agco. Everything I have bought for the tractor so for including the salvage crank has come from the same dealer and it's the same parts they use in there own shop. The main parts guy is very helpful and prices are close to what I could order them for.
  4. #24
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Another thing to be aware of is the upper gasket set I used was TISCO brand and was not complete. The soft washers for the injector return lines and washers for the oil line that goes from the head to the block were not included. Think there was more not in the kit, but that all I can think of right now. I also bought separately new rubber seals that go around the top of the injector to help keep crud out and new rubber inserts for the fuel lines in the filter base and incoming and out going lines of the injection pump.
  5. #25
    Member
    Join Date
    Nov 2011
    Posts
    37
    Central KY
    Massey Ferguson 135
    If I drop the oil pan, can I change the connecting rods and pistons withOUT removing the crankshaft and having to re-time the engine?
    I was really wanting to avoid even removing the oil pan, since it is part of the support structure, because of the working conditions that I stated in earlier posts. But the more I think about it, I just hate to be this far into it without at least knowing the condition of things...... I guess I will wait for an answer to this question and then I will decide.
  6. #26
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    Absolutely, the pistons and connecting rods may be removed and reinstalled without removing the crankshaft. After all, it would be a shame to get the top end done, only to discover that the bottom end has problems.
    Regarding your working conditions, I my youth, I've rebuilt 350 4 bolt main Chevy engines without even so much as a roof over my head. In your case, you can mitigate the problems posed by having a dirt floor by using 6 mil rolled plastic sheet and/or a sheet of 4x8 plywood to work on.
    My suggestion would be to do it right, the first time.
  7. #27
    Member
    Join Date
    Nov 2011
    Posts
    37
    Central KY
    Massey Ferguson 135
    You da man! That's my inspiration. I'm gonna do it.
    If my thinking is correct, as long as I dont remove the crankshaft from this engine, I wont have to re-time it coorect?
    Also, if I pull the pistons, I should probably just do a whole rebuild kit. Re sleeve the cylinders and replace the pistons. Or would I be okay with just new rings?
  8. #28
    Platinum Member bucktaker's Avatar
    Join Date
    Apr 2010
    Posts
    907
    Sw Ohio
    Kubota L5740
    Massey Ferguson 135 Rebuild Journey (diesel)-196-jpgAt this point just support the center of the tractor and drop the front end, remove the motor, set up a semi clean work bench /floor and do the whole thing.. A machine shop can resize the rods, check the crank and even reassemble it. Then you just put her back together.... Finished my mf35 last fall Massey Ferguson 135 Rebuild Journey (diesel)-182-jpg
    Kubota L5740 La854
    MF 35 Deluxe gas wloader...For sale
  9. #29
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    No, if you don't remove the crankshaft the engine wouldn't need to be re-timed. Regardless, even if it needed done, re-timing the engine is a snap so it's really nothing to worry about. If the cylinders measured within specs, they could be lightly honed to break the glaze, then new rings installed. Assuming everything else is okay.
    Honestly, if it were me I'd simply remove the engine and do a complete rebuild. One simply needs to remove the front end assembly, which is not difficult. Then you'd only need an engine hoist or some means of lifting the engine and pulling it away from the tractor.
  10. #30
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Timing of my AD4.203, big brother to your engine
    Massey Ferguson 135 Rebuild Journey (diesel)-ad4timing-jpg
Similar Threads
  1. We have liftoff of my Massey 135 Rebuild
    By Forester Massey in forum Massey Ferguson Classic/Vintage
    Last Post: 03-31-2013, 09:45 PM
  2. Massey 135 Front End Rebuild
    By moparman in forum Massey Ferguson Classic/Vintage
    Last Post: 07-12-2012, 12:35 AM
  3. Massey Ferguson Exhaust Rebuild
    By ChuckE2009 in forum Welding
    Last Post: 06-02-2012, 09:07 PM
  4. Massey Ferguson 135 Diesel head torque
    By wallyb147 in forum Massey Ferguson Classic/Vintage
    Last Post: 12-31-2011, 10:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
