Results 1 to 8 of 8
04-01-2013, 07:54 PM #1New Member
- Join Date
- Jan 2013
- Posts
- 23
- Location
- PA
- Tractor
- Massey Ferguson 135 Deluxe
Massey Ferguson 135 Position Control Not Working
My Position Control is not working. On other sites I have seen references to this issue: speciifcally the position control linkage becoming displaced when the position control lever is moved outside of its normal range of motion. Back in 2004 on a forum in Yesterday's Tractors, Big Dean Austin stated that "the Position control has a piece of linkage that when you move the position lever to (sic) far it will jump out of place it will happen almost every time you do that. To get it back where it belongs you will have to remove the liftcover. I have a picture showing this & how to get it back in place." Does anyone know anything about this or have the fix that Big Dean was referring to?
Thanks!Last edited by klancf51; 04-02-2013 at 10:02 AM. Reason: correction
04-04-2013, 07:28 PM #2Bronze Member
- Join Date
- Aug 2012
- Posts
- 69
- Location
- Bowling Green Kentucky
- Tractor
- Massey 135
Re: Massey Ferguson 135 Position Control Not Working
I too have the same problem and have not heard of this. Its possible I have done the same thing. Its likely you would have to remove the top cover. I have both my side covers off and notice some parts move when I move the draft control but nothing when I move the position control. Not sure I am supposed to see anything move.
04-09-2013, 11:15 AM #3New Member
- Join Date
- Jan 2013
- Posts
- 23
- Location
- PA
- Tractor
I have the top cover ready to hoist, but I would sure like to have some understanding of the problem and the fix before I get into it. From what I have been able to gather, Big Dean did not post the fix, but instead directly emailed it out to some people on Yesterday's Tractors forum (Matthew Rice from Alabama I believe). It appears that this problem is not uncommon and the fix really should be documented with pictures and posted. If I figure it out I will post it. Thanks for the reply.
04-09-2013, 11:18 AM #4Super Member
- Join Date
- Nov 2011
- Posts
- 6,454
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
04-09-2013, 11:56 AM #5Platinum Member
- Join Date
- Feb 2012
- Posts
- 549
- Location
- Germanton, NC
- Tractor
- Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
I've had that very problem you describe. I had our local tractor mechanic fix it. I believe it took longer to pull the cover than to get the linkage bak in alignment.
04-09-2013, 05:47 PM #6New Member
- Join Date
- Jan 2013
- Posts
- 23
- Location
- PA
- Tractor
04-09-2013, 07:43 PM #7Silver Member
- Join Date
- Jul 2012
- Posts
- 113
- Location
- Central Iowa
- Tractor
- MF 135 Deluxe
Check out lugnuts thread 73 135 Perkins diesel thread. He had problems with his position control and removed his auxiliary valve and replaced it with the standard cover plate and still had problems. It appears that he pulled the top cover and found an adjustment bolt for the position control unscrewed and is currently trying to contact Hutch for advice.
04-27-2013, 09:00 AM #8Silver Member
- Join Date
- May 2012
- Posts
- 219
- Location
- Western Australia
- Tractor
- Massey Ferguson 148 .Chamberlain Super 70. Caterpillar D4. Chamberlain 354 FEL.Toro 268 rideon toro zero turn reel
G'day klancf51 .
To better understand your problem can you give me in your words what the tractor is not /is doing that you feel it should /should not do.
Caution. Do not remove the lift cover until you are comfortable that you know what you are doing or it may cost you a control valve or at the least a lot of time fixing the mistake you made, usually through the lack of knowledge, or the NEED to RIP things to bits, anyway tell me all you know and I will talk you through your Dilemma.
happy days.
Hutch.
Similar Threads
Massy 135 position control not working.
By lmbr in forum HydraulicsReplies: 0Last Post: 03-30-2013, 10:41 PM -
Buying Advice Massey Ferguson 135
By pbman in forum Buying/Pricing/ComparisonsReplies: 32Last Post: 03-18-2013, 04:34 PM -
MAssey Ferguson 135
By AngelaGay in forum Parts/RepairsReplies: 1Last Post: 08-03-2009, 01:19 PM -
Massey Ferguson 135 UK
By van1 in forum Massey Ferguson Classic/VintageReplies: 0Last Post: 06-14-2006, 08:07 PM -
Massey Ferguson 135
By SCDolphin in forum Massey Ferguson Classic/VintageReplies: 13Last Post: 08-03-2005, 08:15 AM
