Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2011
    Posts
    91
    HST3710, FZ2100
    Default No gasket on Z134 engine oil pump with low oil pressure, is that right?
    Hi, this is a follow on to another post about low oil pressure on an otherwise good running Massey F40 with a z134 engine. The oil pump, which may have been original and untouched, had no gasket on the side plate that covers the two oil pump gears. The Tisco oil pump repair kit I just received does have a gasket. The side plate seems to be very tight fitting and I cant imagine much oil escaping, but it does leave the question as to which is right, gasket or no gasket on the side plate. Presumably placing the gasket on there could create some clearance that should not be there, so i am a bit lost. Any help appreciated.
  2. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default Re: No gasket on Z134 engine oil pump with low oil pressure, is that right?
    Tex, it would be a big help if you would keep everything dealing with your F40 in the same thread. There is no need to create a new thread when asking a related question. One side I believe doesn't have a gasket. That side you check wear with a feeler gauge. Are you working with a manual?
  3. #3
    Join Date
    Feb 2011
    Posts
    91
    HST3710, FZ2100
    Well, ok then, back to the old thread I go....there is only one side that comes off,as far as i can tell...
Similar Threads
  1. Dropping oil pan on 1957 F40 with gas Z134 because of low oil pressure...
    By Texwing in forum Massey Ferguson Classic/Vintage
    Last Post: 03-28-2013, 07:04 PM
  2. BX -- low oil, or low oil pressure engine shutdown?
    By wrooster in forum Kubota Owning/Operating
    Last Post: 08-08-2011, 11:06 AM
  3. Oil & Fuel Oil Pump Gasket
    By Jinma284 in forum Chinese Tractors
    Last Post: 03-25-2011, 12:21 AM
  4. low oil pressure
    By robert421960 in forum Chinese Tractors
    Last Post: 08-18-2010, 11:54 PM
  5. Oil & Fuel DK35 with low engine oil pressure
    By tedder in forum Kioti Owning/Operating
    Last Post: 01-16-2008, 01:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
