Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default Re: 135 leaking utf
    Quote Originally Posted by YesDeere View Post
    Bout 2 qts over
    Keep your tranny hydro fluid level at FULL or just slight above it if your using hydro attachments. They put marks on those dipsticks for a reason. -kid
  2. #12
    Join Date
    Mar 2013
    Posts
    247
    Heaven on earth
    MF
    Quote Originally Posted by The kid View Post
    are three point arms suppose to be up or down when checking fluid level? Lift cylinder hold a lot of fluid. That why when you change it you are suppose to lower the arms to drain as much oil out of the system.
  3. #13
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    Quote Originally Posted by SIMassey View Post
    I suggest you direct that question to someone you feel knows the answer.
  4. #14
    Gold Member
    Join Date
    Jul 2012
    Posts
    316
    guess where
    xyz
    I checked my owners manual and as you stated you are supposed to drain the fluid with both hydraulic control levers in the down position and fill with 8 gallons of m1129 or m1129a oil. The manual does not state whether you have the three point arms up or down when checking the fluid level. It just states that the fluid level must be between the arrows on the dipstick.
  5. #15
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Yes, down is the answer.
    Murph
  6. #16
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    in the end.. the lift cyl holds very, very little. up or down on the 3pt lift will amount to 'ounces; of oil displacement..
    i'd personally check down to prevent any chance of overfill..e tc.
Similar Threads
  1. MF 135 Carb Leaking Gas (1967? Continental Gas)
    By CreekRRTRN in forum Massey Ferguson Classic/Vintage
    Last Post: 12-20-2012, 10:34 PM
  2. Massey Ferguson 135 Fuel Injector leaking
    By qwerty11 in forum Massey Ferguson Classic/Vintage
    Last Post: 08-12-2011, 02:06 PM
  3. MF 135 isolating selector valve leaking
    By Ice1 in forum Massey Ferguson Classic/Vintage
    Last Post: 10-31-2009, 09:23 AM
  4. MF 135 isolating selector valve leaking
    Last Post: 10-31-2009, 02:57 AM
  5. MF 135 year of manufacture is 1969 leaking coolant
    By dexter195 in forum Parts/Repairs
    Last Post: 09-19-2005, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
