Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jul 2011
    Posts
    7
    Wales
    MF 178
    Default Massey 178 starter ring replacement
    Hi there. The starter ring on the flywheel of my MF 178 is badly worn and needs replacement. The tractor will have to be split and the new ring fitted. While I will not be doing this myself does anyone know how many hours of labour I should expect to be charged for by my mechanic. Many thanks.
  2. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default Re: Massey 178 starter ring replacement
    Is this a UK tractor?
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Welcome from Ohio
    Murph
  4. #4
    New Member
    Join Date
    Jul 2011
    Posts
    7
    Wales
    MF 178
    Quote Originally Posted by The kid View Post
    Yes it is. Now living in Ireland.
  5. #5
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Quote Originally Posted by mick101 View Post
    Just a guess Mick. But probably take no more than six shop hours or less. With the right equipment, It wouldn't take as long as you think to split a tractor. The gear ring is probably heated to remove and install. If the flywheel needs resurfacing would add more. They are going to look at your clutch too. -kid
  6. #6
    Join Date
    Jan 2013
    Posts
    91
    PA
    CASE IH
    Just a guess Mick. But probably take no more than six shop hours or less. With the right equipment, It wouldn't take as long as you think to split a tractor. The gear ring is probably heated to remove and install. If the flywheel needs resurfacing would add moe going to look atyour clutch too. -kid
    The ring gear is removed by partially cutting through it and then chisel splitting it with a cold chisel. The idea is to not cut the flywheel. Alternative is to flame-heat a portion of the ring gear and then carefully tap it off the flywheel.
    To install, heat ring gear to 475 F. Orient the ring gear such that the lead-in side of the teeth is toward the front of the flywheel, then lay the ring gear into position, being sure that the ring gear is fully against the flywheel shoulder. Allow to cool. Good call on clutch (don't forget release & pilot bearings) - the incremental labor cost for these is small at this point of disassembly.
Similar Threads
  1. 3-Point Hitch massey ferguson 178 3 point won't lift weight
    By zpainter1015 in forum Massey Ferguson Owning/Operating
    Last Post: 07-13-2012, 01:44 AM
  2. Oil & Fuel LX 178 axle seal replacement
    By fatboy999 in forum John Deere Owning/Operating
    Last Post: 04-01-2012, 07:54 PM
  3. ring setting replacement
    By coachgrd in forum Rural Living
    Last Post: 07-08-2008, 11:24 AM
  4. Jinma 354LE Flywheel / Starter ring # of TEETH
    By GuglioLS in forum Chinese Tractors
    Last Post: 07-01-2005, 01:17 AM
  5. Massey Ferguson 178
    By Anonymous Poster in forum Massey Ferguson Owning/Operating
    Last Post: 05-02-2003, 08:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
