Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,584
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: Is it possible to identify this?
    Is the 3 cylinder diesel a Perkins? Could be a late late Model MF35. Normal consumable parts are available and wrecking yards might have other parts. The MF 35 was pretty popular.Parts are available.
  2. #12
    Join Date
    Aug 2010
    Posts
    60
    south africa
    Thanks everyone
    The 35's and 35X were very popular here, and Ive found a few places that have spares, so hopefully it will be arriving next weekend.
    This will be one **** of a rebuild! I'll post some pictures as I go.
  3. #13
    New Member
    Join Date
    Apr 2012
    Posts
    12
    Latrobe Valley, Victoria
    Fergies TEA20 (80mm Bore, vertical oil filter) & FE35 (3 cyl Perkins)
    Owned a few of these , looks like a FE35 to me.
    The two stage clutch was an option over here.
    They are a gr8 jigger with the 3 cyl perkins.
    Does it have a diff lock?
    The perkins has its own clutch check the pot depth and set the fingers to the book.
    A bit of effort with more photos would help.
  4. #14
    Join Date
    Aug 2010
    Posts
    60
    south africa
    I'll be fetching the old girl this weekend, I'll post some pics because I'll be needing lots of help
    thanks all
    Discrimination…is unfair unless it is established that the discrimination is fair.” Section 4.56.5 of Zimbabwe’s new Constitution
  5. #15
    Gold Member cmore's Avatar
    Join Date
    Jul 2012
    Posts
    261
    nw tn
    traded MF135 for a 2605 4x4
    My late 60's 135 had a different seat spring (one leaf) and only had a single fuel filter with a sediment bowl beneath it.
    It has a 3 cycl diesel Perkins
  6. #16
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default
    Quote Originally Posted by zimbo View Post
    Thanks everyone
    Where is here? You have no location in your profile.
  7. #17
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    The dash shape and the top of the transmission does not resemble my TO35 one bit.
    modify, adjust and improvise....a country boy can survive
  8. #18
    Join Date
    Aug 2010
    Posts
    60
    south africa
    Quote Originally Posted by The kid View Post
    That would probably help a lot! I'm in South Africa.
    I didn't take a camera with me yesterday, (idiot). It is a 3 cylinder Perkins that seized after running with no oil, the crankshaft is a bit stuffed, so I'll see if it can be fixed, but the rest looks pretty good. The engine is in pieces in a couple of boxes, so I have to make sure I find all the bits. Luckily I can go back and dig around if I forget anything.
    Im collecting it tomorrow, so I'll post some pictures then. Got to figure out a way to get it off the trailer today, thats going to be fun.
  9. #19
    Join Date
    Aug 2010
    Posts
    60
    south africa
    Ok, so the tractor is home, Its a 35 serial No 298833 so looks like a 62 or 63 model.
    The engine has gone to an engineering company for a quote on a rebuild.
    The crank is quite badly scored, pistons and sleeves aren't great, but the rest looks ok.
    Ive got quite a lot to do on the body, Im probably not going to get it to showroom condition, but it will be a pretty good looking little working machine one day!
    Some pics to start off with.
    Is it possible to identify this?-p1070241-jpgIs it possible to identify this?-p1070239-jpg
    There is a massive tow hitch contraption, held up by very tight chains. I may take it all off at some stage and get a more "streamlined" version, this takes about 10 cm of ground clearance away.
    Problem No 1 is an oil leak coming out through the right side brake drum, Problem 2 is the screws holding the brake drum in place are stuffed!
    Is it possible to identify this?-p1070243-jpgIs it possible to identify this?-p1070242-jpg
    Any idea how to get these out?
    Another issue is this
    Is it possible to identify this?-p1070240-jpg
    Im not sure of the proper name, its on the right side of the body where the pin controlling the thrust bearing goes through the casing, will I need to get a bush made to stop any more wear?
    I dont know if I should start another thread for all my stupid questions, or keep going here?
    Cheers
    Ryan
  10. #20
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    High heat (torch) is always good to break down rust. You may have to chistle the groove back in place. They make a impact driver, when you hit it with a hammer, it torques right or left which would help. High heat and impact screw driver will get the job done. Soak it good with a high quality penetrating oil.
    As for your thread. Yes I would start a new one that described what you are doing. Something like "Reclaiming a MF35 Barn Find - South Africa" or something similar. -kid
Similar Threads
  1. Backhoe How may I identify this 757 BH?
    By HavnFun in forum Attachments
    Last Post: 12-27-2009, 12:57 PM
  2. How to identify my FEL?
    By Phoenix Farmer in forum Kubota Owning/Operating
    Last Post: 05-06-2009, 01:42 PM
  3. Can you identify this?
    By gsdavis1 in forum Projects
    Last Post: 03-28-2008, 08:22 PM
  4. Help Identify
    By JB4310 in forum General Vintage Tractors
    Last Post: 02-02-2008, 10:35 PM
  5. need some help to identify
    By dsn142 in forum Kubota Owning/Operating
    Last Post: 01-11-2008, 10:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
