Page 2 of 9 FirstFirst 12345 ... LastLast
Results 11 to 20 of 82
  1. #11
    Gold Member
    Join Date
    Jul 2012
    Posts
    316
    guess where
    xyz
    Default Re: AMD's 1968 MF 135
    Others have said that "we" should be able to raise and lower the three point from the left hand lever. I have never been able to do that. I have to have the left lever pulled toward the seat and held to either raise or lower the three point using the controls on the right side of the seat. Then to use the loader I have to move the left lever to the center position and keep the position lever pulled all the way back on the right side of the seat in the constant pumping position. I cannot use the loader and three point at the same time. If you have the left lever pulled and try to run the loader the three point does strange things. As I noted in my above post. My loader lifts when I pull the right hand lever toward the seat and lowers pushed away. I never need to move the position or draft lever to raise or lower the loader. You need to hook the hose to the loader to the correct fitting to raise while pulling the right lever toward the seat. Then you should be able to lower the loader by pushing the lever away from the seat. If you don't change the hose location, you will need to screw that valve back in I think.
    I have the same problem with the trip bucket. I have since added a front pump to the tractor that I use to raise and lower the loader and have added a cylinder to the oversized snow bucket for dumping using the standard tractor hydraulics. In time I intend to change to a joystick and run both from the front pump. I still use the trip for the dirt bucket. I know its awkward moving the lever back and forth to change from loader to three point but you will get used to it.
  2. #12
    Bronze Member AMD's Avatar
    Join Date
    Apr 2013
    Posts
    76
    Carleton Place, ON
    Kioti CK3510
    I'm pretty sure it sounds like mine is acting exactly like yours is, just we're maybe operating a little differently. I'm more than happy to get used to how I need to operate it as opposed to having an issue that needs attention!
    I certainly do like the idea of foregoing the need for a trip bucket but for the time being that is low priority (mainly because of associated costs!)
  3. #13
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Try this wiring diagram on for size. It was posted some time ago. Kinda small in size but reveals alot.
    MF 135 Wiring. One of our members originally posted and colorized part of the wiring. It does show dual beam headlight wiring to the switch. -kid
  4. #14
    Join Date
    Apr 2013
    Posts
    76
    Carleton Place, ON
    Kioti CK3510
    Quote Originally Posted by The kid View Post
    Thanks kid! That looks helpful for sure - I had something similar from a 165 but not as detailed with regards to pinouts on the switch. I'll get that printed when I'm not on my phone. Thanks again!!
  5. #15
    Join Date
    Apr 2013
    Posts
    76
    Carleton Place, ON
    Kioti CK3510
    Also got my muffler / exhaust pipe yesterday and despite the dimensions listed on the AGCO website the vertical drop was 18" so it fit like a charm! I'm happy and wife's happy cause I don't smell quite as terrible after being out on the tractor anymore!
  6. #16
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    Quote Originally Posted by AMD View Post
    I've got another wiring diagram that shows wire colors. When I find it I will post it here.
  7. #17
    New Member
    Join Date
    Jun 2013
    Posts
    1
    creston bc
    masssey 135
    I am looking to buy the adjustment blocks on the chains of the 3pth. anybody know where I can find them?
  8. #18
    Join Date
    Apr 2013
    Posts
    76
    Carleton Place, ON
    Kioti CK3510
    So I still haven't gotten the lights working, just haven't had much time to get at it. I did finally remove the rear fenders last night - they were awfully wobbly and I wanted to clean them up (paint maybe??) and the lighting wiring inside.
    Question - does anyone else have the flat top fenders that have one light in both the rear and front of the fender?
    I tested the wiring with a power supply and on both fenders only the one light illuminates. The other light has a single red wire running to it. I'm connecting the power supply to the red on one side and the black and white (which are connected) on the other side. I looked around on Agco parts book this a.m. but the diagrams for lighting don't really incorporate the in fender lights, and the fender diagram doesn't show lighting. I don't think the wiring is wrong but of course it is a possibility. If anyone else has this set-up is there also just the one large wire going to the rear light?
    I plan to post some pics soon too...
  9. #19
    Join Date
    Apr 2013
    Posts
    76
    Carleton Place, ON
    Kioti CK3510
    When I brought it home:
    AMD's 1968 MF 135-img-20130413-00342-jpg
    Here's how it stands now - haven't done much but I did flip around the seat and fix up the front nose cone.
    AMD's 1968 MF 135-img-20130517-00432-jpg
  10. #20
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324073"/>
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324074"/>
    Where did you buy your nosecone from?
Similar Threads
  1. mf 135 repairs
    By plunger in forum Massey Ferguson Owning/Operating
    Last Post: 08-01-2013, 06:44 AM
  2. Takeuchi 135
    By Degolyerent in forum Construction Equipment
    Last Post: 06-30-2013, 01:52 PM
  3. mf 135 hyd
    By butchtn in forum Parts/Repairs
    Last Post: 05-12-2013, 08:37 AM
  4. steering leak on mf 135
    By jcuzz in forum Massey Ferguson Classic/Vintage
    Last Post: 05-07-2013, 04:39 PM
  5. PTO froze up on Massey 135
    By Gwindel in forum Parts/Repairs
    Last Post: 05-05-2013, 04:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
