Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Member
    Join Date
    Mar 2013
    Posts
    32
    Lake Leelanau
    John Deere 5105
    Default Re: Oil leak on mf135
    I added it. This is getting in the weeds. I've asked the mechanic to come by Monday. Good evening.
  2. #22
    Gold Member 7879fordman's Avatar
    Join Date
    Apr 2013
    Posts
    339
    gillham arkansas
    1969 massey 135 and a 2013 m7040hd 4x4 2013 L3800 HST 4x4
    Default
    Quote Originally Posted by Soundguy View Post
    your message is very unclear.
    you are saying the front bolster was cracked and they used rubber sealer on it?
    or they replaced it and then used rubber sealer on ? what?
    and what is leaking?
    10-40 and 20-50 are S rated oils. hope that is a gas tractor and not a diesel.
    post back what the SPECIFIC damage is if you want specific answers.
    Both them oils are diesel oil .... Don't know why u think there not . My brand new ford diesel truck has 10-40 . And rotella 20-50 is common as **** in diesels . Wow really guys .
  3. #23
    Gold Member
    Join Date
    May 2012
    Posts
    362
    Gidgiegannup Springs, Western Australia
    Massey Ferguson 148 .Chamberlain Super 70. Caterpillar D4. Chamberlain 354 FEL.Toro 268 rideon kubota L2002fel
    G'day ts1986.
    And welcome to the forum,I got a bit confused then Mr ed Hijacking your issue Maybe he should go to the case site!!!
    Anyway ,if as you say there is a small puddle of oil on the floor next morning and you can live with that I would leave it alone.
    The oil leaking from the rear crankshaft seal will track down Behind the flywheel into a small oil catchment area and as you have seen comes out Via The JIGGLE PIN and as has been said the reason the Jiggle pin is there is to stop the hole from being clogged up.
    There will be no real risk of the clutch being contaminated just Keep an eye on it ,My 148 has leaked like that for more than ten years and has not got any worse.
    Happy Days.
    Hutch.
  4. #24
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by 7879fordman View Post
    there's not a single store in the tri cirty area i liv ein that has any kind of a 10-40 or 20w50 oil that is anything other than S rated.
    Only c rated oils i can get locally are 5w40, and 15w40, 30w straight and 40w straight, and can order 10w30. Our bulk oil dealer doesn't even have a 10-40 or 20w50 on our order sheet.. what ar ethe part numbers? I'd like to look at these other diesel oils.
    souNdguy
    sent from my NOKIA LUMIA
  5. #25
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    edit:
    OK.. I see amsoil has a 20w50 synthetic diesel oil.
    I see if you live in malasia you can get a castrol RX 20w50 ci-4 oil.
    if you live in japan.. enos makes some 20w50 ci-4
    In fact. i found a good hadfull or 20w50 and maybee 1 10w40 oil.. .. i say maybee as I couldn't read the language. all were outside US distribuitors.
    Whos got some us info? amsoil is all i can find so far.
    souNdguy
  6. #26
    Join Date
    Apr 2013
    Posts
    339
    gillham arkansas
    Default
    Motorcraft - roltella . And there's a few more that make it easy to get .
    Sent from my iPhone 5 using TractorByNet
  7. #27
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    i can get motorcraft and rotella locally. had been using motorcraft in my powerstroke. but all they have locally in motorcraft is the hd diesel 15w40 non syn oil.
    rotella has a few offerings. t5/6 etc. but nothing in 10-40 or 20w50.
    perhaps it's a reginal temp thing. I know to get 10w30 diesel oil we have to roder froma distribuitor in the north. perhaps in a arid / hot area is where the heavier diesels are more readilly stocked?
    can get bulk 30w straight and 40w here for heavy equipment.. etc...
    souNdguy
  8. #28
    Join Date
    Apr 2013
    Posts
    339
    gillham arkansas
    Default
    Can get any weight you want in Arkansas easy .
  9. #29
    Member
    Join Date
    Jul 2009
    Posts
    45
    Ontario, Canada
    Hey guys, just weighing in, 10w30 diesel grade in the 135 because it gets more work in the winter. But with that weeping hole make sure it stays open or take the clutch inpection plate off if it is too bad. This past winter blowing the snow out of the neighbours driveway the oil didn't "weep" fast enough, it has a steep hill, and it got to the clutch. It ended that job quick enough. The clutch seems to work all right now but needs to be replaced before it spins too much on the flywheel.
  10. #30
    Gold Member
    Join Date
    May 2012
    Posts
    362
    G'day Brakeman.
    If the clutch is SLIPPING it needs to be adjusted, When properly adjusted WET OR DRY it wont slip.
    If as you say the oil was more than a WEEP maybe the job should have been done some time ago!!!
    Hutch.
Similar Threads
  1. How to find a oil leak on a x728 John Deere
    By rubadub in forum John Deere Lawn & Garden
    Last Post: 06-08-2013, 09:52 PM
  2. Oil & Fuel MY FERGUSON 35 DELUXE OIL LEAK AT FILTER HOUSING
    By JONJON in forum Massey Ferguson Classic/Vintage
    Last Post: 05-19-2013, 11:21 PM
  3. john deer 425 oil leak
    By art wannamaker in forum John Deere Lawn & Garden
    Last Post: 05-13-2013, 10:47 PM
  4. Massey Furguson 3545 oil leak
    By accomackorganic in forum Parts/Repairs
    Last Post: 05-10-2013, 08:22 AM
  5. Oil & Fuel Iseki TM3240 Oil Leak
    By avtar412 in forum Iseki
    Last Post: 05-07-2013, 05:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
