Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    9
    Ooltewah, TN
    Massey Ferguson 165 Diesel
    Default 1964 model 165 Diesel/ Oil Leak
    I was grading the driveway the other day and noticed a decent amount of oil between the engine and tranny. It was on top of the bellhousing and running down. Could this be coming from the oil pan gasket or what? Also, where is the best place online to purchase the manuals for the 165? I assume the owns, parts, and service manuals are still available. I would like them on CD, if possible.
  2. #2
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,402
    Ararat Vic Aus
    Default Re: 1964 model 165 Diesel/ Oil Leak
    G'day if it is on top of the outside of the bellhousing and running down then it is prob a rocker cover gasket or an oil pressure gauge feed line, I doubt very much it is the pan gasket and blowing up to the top of the trans.
    Have a bit of a clean down and check the oil level before starting then start it up if it is a constant stream then it will be an oil press line, it will usually take a fair while for a rocker cover gasket to leak down the back
    Jon
  3. #3
    New Member
    Join Date
    Jun 2013
    Posts
    9
    Ooltewah, TN
    I cleaned it up and ran it again and no oil on top of bellhousing. I did notice that a small drip of oil coming from below though. I checked with the previous owner and he used Rotella 15w40. A friend told me that the rear main seal was probably the problem. I guess buying old tractors can get a little frustrating. Can you advise on adjusting the multipower shift linkage. It wants to stay in low.
Similar Threads
  1. oil leak
    By allen6634 in forum Ford Vintage Tractors
    Last Post: 05-28-2013, 06:08 PM
  2. Loader 1964/65 IH 504 4cyl Diesel
    By Bogey679 in forum Case-IH
    Last Post: 09-15-2012, 03:38 PM
  3. 1964 case 430 diesel in oil
    By papab in forum Parts/Repairs
    Last Post: 05-09-2011, 02:40 PM
  4. 1964? Ford 3000 diesel engine has very slow acceleration
    By humbll in forum All Other Brands
    Last Post: 03-20-2011, 10:10 AM
  5. The 1964 MF-135 diesel is overheating
    By flusher in forum General Vintage Tractors
    Last Post: 08-09-2007, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
