Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Join Date
    May 2012
    Posts
    56
    Northern VA
    Massey 2135, Sears Lawntractor
    Default Continental Z134 starting problem
    Looking at a gas MF2135 (Continental Z134) that was sitting for a couple years, that a friend has. After putting a gallon in the tank, and replacing the battery, it cranked up, but only runs with the choke.
    It stops if you push the choke in.
    Any thoughts on what it might be, what to look for, or how to fix that?
    Continental Z134 starting problem-forumrunner_20130701_124049-png
  2. #2
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,436
    Ararat Vic Aus
    Default Re: Continental Z134 starting problem
    G'day either a blocked fuel line/filter to the carb or a blocked carb. Pull the fuel line at the carb and see if you have good fuel flow if so then the carb has prob gummed up from sitting around.
    Jon
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by banjodunn View Post
    Jon
    x2
    Murph
  4. #4
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,572
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    If it only runs with the choke on, then the mixture is too lean or you have a weak spark. (Weak sparks need a richer mixture.) Clean and check the points, then check the spark. Often the points are corroded or oily especially if the tractor has not be used for long periods of time. If you get a fat, bluish-white spark, the color of lighning then check the mixture setting on the carb. The idle air should be out ~ 1 full turn and main jet should be out 1-1/8 turns (M-S Carbs only).
    The other possibility for a weak mixture is an air leak around the carb's metering section. The usual culprits are air leaks around the throttle shaft, at the carb/manifold interface, cracks or rust spots on the intake manifold, and air leaks at the manifold to head interface. CAREFULLY spraying starting fluid at these areas while the engine is running will help find these leaks. The engine will speed up when you spray starting fluid at the leak.
    It's also possible that the idle air passage is partially clogged and/or the main jet is similarly blocked but make the above checks first before you go tearing into the carb. Most poblems on these engines result from weak sparks, poor carb adjustments, or air leaks around the carb metering sections.
  5. #5
    Join Date
    May 2012
    Posts
    56
    Northern VA
    Well I got the tractor home, and now the fun begins.
    Ordering the AGCO manuals now.
    One question, do the 2135 Manuals also cover the Z134 Gas engine, or is that a separate manual?
  6. #6
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    I would start by cleaning the carb. sounds like a plugged mainjet and emulsion tube to me !
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  7. #7
    Join Date
    May 2012
    Posts
    56
    Northern VA
    Ok, looking at the disassembly process.
    The Air Inlet to the Carb on left side is a rigid pipe connected with a rubber sleeve with two pipe clamps.
    The gas line is on the front right, and the carb is connected to the engine with two upper bolts.
    Is there any special things to do in removal?
    It appears I will have to loosen or remove the air filter in order to get the rigid air intake tube moved.
    Dumb question: to clean the carb, is that just a quick spray clean into a few holes, a partial tear down, or is that a full tear down and rebuild?
    I presume i need to get new gaskets?
  8. #8
    Join Date
    May 2012
    Posts
    56
    Northern VA
    Default
    Here are the pics of the carb.
    Continental Z134 starting problem-forumrunner_20130825_002206-png
    Continental Z134 starting problem-forumrunner_20130825_002256-png
  9. #9
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    That appears to be a Marvel Schebler carb. They where used on a few brands on tractors. Rebuild kits are readily available for it. They are not hard to rebuild which would be the most inexpensive route.
  10. #10
    Join Date
    May 2012
    Posts
    56
    Northern VA
    Default
    Yes, it is the Marvel 882.
    I took it off today, and ordered the rebuild kit from Walts.
    Because I haven't removed the loader, it has been a slow process. I also saw that the AGCO manuals (arrived last night) have no details on removal.
    So, to help me remember the steps after rebuild, I will post the removal sequence here.
    1) turn off fuel at gas sediment bowl.
    2) remove air filter assembly.
    This is 4 bolts (1/2" Socket/wrench) next to battery, and then hose clamps as needed. For this process, I removed the air assembly for cleaning (9/16 Socket).
    3) remove gas line. Note, this is a brass connection.
    4) undo 2 nuts holding top of carb to intake. Left one is difficult, consider getting stubby wrenches (1/2" Wrench).
    5) disconnect rod to governor. via Cotter pin.
    6) disconnect choke cable. Take a close look at how this was hooked up. This is two parts, the rod is in a brass block with a bolt clamping (use 1/4" socket), while the cable case is clamped via a screw (use flat screwdriver, or the 1/4" socket).
    7) Remove carb, wiggling out. Careful, fuel may spill.
    Now, I'm looking for MS 882 carb rebuild instructions, the 2135 AGCO pack didn't have that. It does have some instructions on basic settings after installation.
    Last edited by Cromagnum; 09-01-2013 at 01:16 AM. Reason: Adding socket/wrench sizes
Similar Threads
  1. Massey 135 Z134 Governor
    By dragracergo in forum Parts/Repairs
    Last Post: 06-11-2015, 08:16 PM
  2. Pan is off Z134 Gas engine on Massey f40, now what?
    By Texwing in forum Massey Ferguson Classic/Vintage
    Last Post: 04-09-2013, 02:56 PM
  3. More power from Z134 engine
    By sscott47150 in forum Customization
    Last Post: 02-03-2013, 02:18 PM
  4. MF 35 Overhaul z134
    By bucktaker in forum Massey Ferguson Owning/Operating
    Last Post: 10-18-2012, 12:37 PM
  5. continental z134 distributor
    By 94yj in forum Private Party Ads
    Last Post: 05-24-2011, 05:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
