crowbar032
Gold Member
- Joined
- Jan 19, 2012
- Messages
- 341
- Location
- Moores Hill, Indiana
- Tractor
- MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
I'm at a loss here. A couple of weeks ago, I used this tractor to rake hay. It mostly ran fine. Occasionally, it would miss but then pick back up and run fine. I thought it was just cheap gas (stupid ethanol) or some crud running through the lines. After I finished, I parked it in the barn and didn't start it for about a week. When I started it, it idled ok, but under load it developed a bad miss then finally died. It will not re-start. It cranks strong, hits for like two licks then nothing. I did the normal things....changed plugs, changed points, changed condensor, changed wires, changed distributor cap, changed rotor button. No change. Took the carb apart and cleaned it, nothing appeared to be clogged (used aersol carb cleaner). I replaced this carb a few years ago...not rebuilt, a new carb. No change. Then I got desperate. Changed starter solenoid. No change. Switched coils. No change. Suprisingly, the inside of the gas tank looks new, no rust and no noticable buildup. I'm not sure what else to check on.
My Dad is convinced it's out of time and that the timing chain is stretched and needs replaced. I'm hoping it's not that invasive. Just looking for other theories and other things to check. Appreciate any thoughts.
Old Gray is part of the family, I'm 36 and I don't ever remember a time without this tractor on the farm....he can't die on me now.
