Results 1 to 10 of 10
  1. #1
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Ferguson TO-30, Kioti LB1914
    Default TSX-458 carburetor (from TO-30) powdercoated and rebuilt
    Finally got this coated and put back together. Started by completely disassembling then blasting the two castings. Outgassed them in the oven and blasted again (some pretty stubborn black junk inside the upper casting after outgassing) before blowing clean, acetone rinsing, masking, and coating. Powder is Prismatic Powders autumn grey (PSB-5946), which is a pretty close match for Yenkin-Majestic "Majic" Massey Ferguson gray 8-22955 paint that they sell at Tractor Supply (darker than the original TO-30 light gray). I swapped out the original slotted fillister head screws (that hold the two castings together) for some stainless socket head cap screws (12-24 x 5/8") and some #10 stainless flat washers with the OD turned down to 3/8".
    Last thing I need to find is a new barb fitting that goes into the fuel strainer elbow. I thought it was just regular 1/8 NPT going into the elbow, but upon measuring the old barb fitting, it appears to be 7/16-24 straight thread. Anyone know where I can get one of these or a part number for it? Should be for 5/16" ID hose on the barb end.
    Attached Thumbnails Attached Thumbnails TSX-458 carburetor (from TO-30) powdercoated and rebuilt-tractor_carb_1-jpg   TSX-458 carburetor (from TO-30) powdercoated and rebuilt-tractor_carb_2-jpg   TSX-458 carburetor (from TO-30) powdercoated and rebuilt-tractor_carb_3-jpg
  2. #2
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Default Re: TSX-458 carburetor (from TO-30) powdercoated and rebuilt
    Update: I found out what the fitting I need is called and have half of it already. It's called an inverted flare swivel. It's a two-piece affair consisting of a brake line nut (in this case, an SAE 1/4" size, which has 7/16-24 external threads) and then the barb body, which has a short projection of tubing that captures the nut when flared. Attached is an example of a 90-degree version (I need a straight one, but this picture showed the two pieces in contrasting colors nicely). Anyway, I went to the auto parts store and picked up a length of brake line tubing that has two of the correct nuts on it. Going to make a simple barb body and flare it over one of the nuts...
    Attached Thumbnails Attached Thumbnails TSX-458 carburetor (from TO-30) powdercoated and rebuilt-inverted_flare_swivel_90-png
  3. #3
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Quick model. I need to make the bluish green part. Center bore is 3/16".
    Attached Thumbnails Attached Thumbnails TSX-458 carburetor (from TO-30) powdercoated and rebuilt-inverted_flare_swivel_assy_x_sec-png
  4. #4
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Quote Originally Posted by dbotos View Post
    I was going this route and because of the intenseheat near the manifold I went with hardline. I already had a tube bender and a high quality tube flaring kit. Bent the line clear away fron any heat and up to the tank cutoff. -kid
  5. #5
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Good idea. I already bought 2 feet of new rubber hose, so I will probably install that and see how long it lasts. But I will remember about hardline if the rubber hose goes south.
  6. #6
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    The OEM never used a barbed fitting. It has a metal fuel line with a flared fitting because it runs under a hot exhaust manifold.
  7. #7
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Good to know. Maybe I will use a length of the hard line I bought to get it well away from the manifold and then adapt to the hose.
  8. #8
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Found some pictures in the owner's and service manuals showing the hard line (must have glossed over that before when reading them). Also mocked up the manifold, carb, and hard line. Definitely needs to jog behind the exhaust outlet. Looks like I might as well put everything back on in order to figure out the routing of the fuel line.
    Attached Thumbnails Attached Thumbnails TSX-458 carburetor (from TO-30) powdercoated and rebuilt-carb_manifold_straight_hard_line_bottom-jpg   TSX-458 carburetor (from TO-30) powdercoated and rebuilt-carb_installed_from_service_manual-png   TSX-458 carburetor (from TO-30) powdercoated and rebuilt-carb_installed_from_owners_manual-png
  9. #9
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    Does your manifold have the original heat shield around it? When I bought mine, I didn't have a heat shield. Somewhere down the road a previous owner removed it. They are a PITA TO WORK AROUND. My manifold had a bad bolting point to the exhaust pipe, so I put a scrapyard good manifold for a Z145 on it. I also located a heat shield and modified it so it's easy to install or remove for any type of servicing. I too had rubber line going to an external fuel filter. When using my tractor I noticed the manifold radiating a tremendous amount of heat. Even though the high pressure fuel line was way away fro the manifold I still was nervous due to heat. I decided because of safety to put it back to a hard line as it was from the factory. All of this is documented in my Refurbish thread in the link in my signature line. -kid
  10. #10
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Nope, no heat shield. Manifold is an aftermarket jobbie that has the triangular exhaust outlet flange instead of the original flare connection outlet. I'm taking the exhaust vertical (already got the elbow, vertical muffler, and rain cap).
    Found the hard line post in your refurb thread - thanks!
    http://www.tractorbynet.com/forums/m...-a-28.html#276
Similar Threads
  1. Marvel-Schebler TSX-458 carburetor choke shaft seal
    By dbotos in forum Parts/Repairs
    Last Post: 07-09-2013, 10:40 PM
  2. Odd goo in carburetor
    By WilliamTO-35 in forum Oil, Fuel & Lubricants
    Last Post: 01-06-2011, 01:57 PM
  3. JD 346 Rebuilt
    By ddivinia in forum John Deere Ag Tractors
    Last Post: 06-15-2010, 08:31 PM
  4. Rebuilt engine for 8N
    By Jefferson_D in forum General Vintage Tractors
    Last Post: 08-20-2004, 06:08 PM
  5. Rebuilt Starter
    By billycalexander in forum Kubota Owning/Operating
    Last Post: 07-28-2004, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
