Results 1 to 8 of 8
  1. #1
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Ferguson TO-30, Kioti LB1914
    Default TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals
    Was cleaning this thing up and in the process of reading the manual, I realized the square portion of the valve stem and the knob that goes on there are gone. So I put the end of the stem in the vise and unscrewed it from the casting. The seals are looking pretty crumbly. And obviously the stem is not all there. Any hope of finding these as replacement parts? The die cast housing has TO-9165 cast into it and "HF" in a rectangle with chamfered corners (assuming this is a Harry Ferguson logo).
    Attached Thumbnails Attached Thumbnails TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals-9165_sediment_bowl_valve_stem-jpg   TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals-fuel_sediment_bowl_x_sec-png   TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals-9165_sediment_bowl-jpg
  2. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default
    Isn't there a screen that stands up inside the tank that acts as a fuel filter? You can still buy this entire cutoff valve new and looks just like yours. The short tube is the reserve I believe when you open the valve all the way. I just put one of those on my 135. Bought it on eBay. -kid
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,249
    Central Ohio
    Kubota MX5100
    Default Re: TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals
    Yes there should be a screen around those stand pipes.
    I wouldnt try to piece it back together. Just get a whole new assembly. They are only $20 Ferguson TO35 Sediment Bowl Assembly (180141M91)
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    I read some complaints about the new aftermarket ones, which is why I was hoping to fix the original.
    http://www.tractorbynet.com/forums/m...nt-bowl.html#2
    http://antiquetractorsforum.com/view...hp?f=19&t=4582
  5. #5
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    Default
    Finding an original may be a tough task. mine has rubber gasket.
  6. #6
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    I figured it'd be a long shot being so old (mine had the rubber gasket too). In the meantime, I rigged up an inline shutoff and filter. The piece of hardline I had purchased was a 20" length, which got it about half way under the battery. I just bent it gently by hand (one jog to avoid the exhaust elbow and then a 90-degree bend to go under the battery). I also completely drained the gas tank this afternoon before I put it back on. Used a coffee filter in a funnel and caught some little bits of junk, but the real kicker was the dead stink bug that came out of there!
    I'm stoked to have the tractor all back together and running again (took it for a victory lap in the driveway/street tonight after adjusting idle speed). I bought the tractor in mid-February and discovered the cracked manifold maybe a week later (ordered new manifold 2-24-13) and started pulling things apart mid-March (have a picture from 3-22-13 with gas tank removed). Nothing really took that long to do, but powdercoating and rebuilding the carb did take a little time cause I was trying to clean everything up real well and make sure I had everything right while it was apart. Most of it was just me procrastinating and other things getting in the way. Now I can work on grading the driveway some more.
    Attached Thumbnails Attached Thumbnails TO-30 fuel sediment bowl (TO-9165) - need new valve stem and seals-homebrew_fuel_valve_and_filter_setup-jpg
  7. #7
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,695
    JD, Massey, Kubota, Case
    Default
    Good job improvising.
  8. #8
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Thanks. I'm hoping I can fix the sediment bowl at some point by machining a new stem and finding the right seals - I just didn't want that to hold up getting the tractor back together. But we all know how a temporary solution can sometimes become a semi-permanent solution...
Similar Threads
  1. Fuel Sediment bowl for B7300
    By tonysmopar in forum Kubota Owning/Operating
    Last Post: 02-13-2013, 06:37 PM
  2. Ford 1700 fuel filter sediment bowl
    By nsmithnd in forum New Holland Owning/Operating
    Last Post: 01-08-2013, 07:56 PM
  3. Draining water from a 3720 fuel sediment bowl
    By Riderguy in forum John Deere Owning/Operating
    Last Post: 01-09-2011, 09:03 AM
  4. Fuel Filter sediment bowl
    Last Post: 12-31-2010, 12:01 PM
  5. Reserve Fuel Tank and Sediment Bowl
    By 8N_John in forum Parts/Repairs
    Last Post: 01-04-2005, 11:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
