8N Ren
Gold Member
Yep that's the one, would be sweet to have.
Take a look underneath there must be a flat spot somewhere there.
Just went out and looked at the axles tubes. They're about 5 inches in diameter where the letters are cast in there, but there's really not a whole lot of length to them between the diff and where the fenders / insides of the wheels are. Doesn't look like there'd be quite enough room to get a jack and jack stand on one tube. I may just stick with the center lift if I can figure out a good way to lock out the front axle from pivoting...
I hope so. I'll lift slowly and check it as I do.
My lathe (and its chuck) are pretty small, so I had to use a vee block in the mill to get one end square before putting it in the lathe to finish up. Got to practice my Etch-a-Sketch circle-making skills cranking the 1/2" end mill around the end face of the ring. :confused2:
