Page 1 of 13 123411 ... LastLast
Results 1 to 10 of 130
  1. #1
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Ferguson TO-30, Kioti LB1914
    Default what are the four holes for in the bottom of the TO-30 differential case?
    Or more importantly, is it okay to use them for interfacing with a jack adapter plate? Holes are about 1/2" diameter on a 3.375" x 6" pattern. Need to lift up the back of the tractor to take one of the wheels off and was thinking about making a jack adapter plate that would have some 3/8"-diameter pins on it that stick into these holes. Other side would have a short length of tubing/pipe that the head of the jack would fit in.
    Attached Thumbnails Attached Thumbnails what are the four holes for in the bottom of the TO-30 differential case?-30_bottom_of_diff-jpg
  2. #2
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Default Re: what are the four holes for in the bottom of the TO-30 differential case?
    Here's what I was envisioning. Plate is 1/4"; pins are 3/8" diameter and stick out 1/2".
    Attached Thumbnails Attached Thumbnails what are the four holes for in the bottom of the TO-30 differential case?-30_rear_jack_adapter_plate_model-png
  3. #3
    Gold Member 8N Ren's Avatar
    Join Date
    Apr 2013
    Posts
    305
    Manitoba, Canada
    8N Ford
    I think it for use with a swinging draw bar if I'm not mistaken.
  4. #4
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Any idea what size bolts? That would make the plate even simpler if I just drill holes in it and use bolts to attach it. The holes under there on mine were pretty dirty - they didn't appear to be threaded - maybe I need to get under there and clean them better.
  5. #5
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    5/8 x 1 3/8ths.coarse.
    Murph
  6. #6
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Excellent - thanks! I'll have to get them cleaned out this weekend if it's not raining.
  7. #7
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,606
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Quote Originally Posted by dbotos View Post
    They are for the drawbar.
  8. #8
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    Got the holes cleaned out this weekend. Good bit of dirt up in them. Used a combination of homemade thread chaser, a semi-spiraling o-ring pick, and a pipe brush to get it all out. They are indeed 5/8-11 with a thread depth of approximately 1.25".
    Also changed the design of the plate so I can use some 1/4" x 4" flat stock I've got laying around:
    Attached Thumbnails Attached Thumbnails what are the four holes for in the bottom of the TO-30 differential case?-30_rear_jack_adapter_plate_model_rev_a-png
  9. #9
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,436
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    All that work to take a wheel off? What are you taking it off for?
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  10. #10
    Join Date
    Feb 2013
    Posts
    208
    southwest VA
    It's not too bad - so far all I've done is futzed around on the computer with designs, laid under the tractor a little bit, and cut a few bolts down (the shortest 5/8-11s that Lowe's had were 2", so I cut them down to 1.375"). Figure it's worth a little time and material for the added peace of mind. I may have to add a hanging hole so I can put it up on the pegboard instead of rummaging and cursing when I need it again.
    Left rear axle seal is leaking. Got oil down inside that wheel. The brakes weren't too confidence-inspiring last time I used the tractor, so I figured I'd better fix that before I use it again.
Similar Threads
  1. Goldoni differential case repair
    By svcguy in forum Welding
    Last Post: 02-03-2016, 09:11 PM
  2. OLD Case 2 bottom plow.....
    By spruce Deere in forum Attachments
    Last Post: 03-18-2013, 10:29 PM
  3. case 580c locking differential
    By forgottenben in forum Owning/Operating
    Last Post: 09-18-2010, 10:42 PM
  4. Case IH 255 differential problems
    By northcreekbound in forum Parts/Repairs
    Last Post: 11-10-2009, 05:31 PM
  5. BX22 front differential case
    By ragman in forum Kubota Owning/Operating
    Last Post: 05-03-2008, 11:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
