Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,408
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Default Re: Restoring My New MF 135
    Quote Originally Posted by Pawell View Post
    Hello Everybody,
    I'm new on forum and new in owning a tractor.
    I live in Poland, Warsaw
    Last week I get a birthday present from my wife and friends and it was a Ferguson.
    It is in very poor shape as you all see on pictures. I'm 90% sure that it is Ferguson 135 unfortunately I can't find any numbers on engine and tractor number is also missing. I'm waiting for owner's manual, maybe it will help me to find out in which year it whose manufactured.
    I hope I will make mechanical restoration in this summer and in the winter I will make it look like new.
    Photos bellow.
    https://plus.google.com/photos/10713...CJ2-ydXw_a7XDg
    Pawel
    Welcome to TBN. Join the fun.
    I found the serial number for my MF135 diesel on the right side of the battery tray. You have to remove the air filter canister to see it.
    Good luck.
  2. #12
    New Member
    Join Date
    Mar 2014
    Posts
    11
    Warsaw
    MF 135
    Thanks for advice. I will look for it today.
  3. #13
    New Member
    Join Date
    Mar 2014
    Posts
    11
    Warsaw
    MF 135
    I found the serial number plate under several lays of paint. Is says 135 416901 M. I whose looking in internet to find more about it and it say that my Ferguson is from 1972 but I don't know what is the M? In mf35 serial numbers it means the double clutch.
    I started to restore the seat. It is a deserter. Someone welded the hinge to the lower bracket and the seat pan need repair. I will they to save lower bracket and seat pan but will need new hinge.
    Restoring My New MF 135-10583838_1440175832937899_6686068565984084352_n-jpg
    Restoring My New MF 135-10577012_1440175892937893_4686209031758432932_n-jpg
    OK. now time for gearbox. I drain it and found 1 liter of something more similar to honey then oil.
    Restoring My New MF 135-10522412_1440659109556238_7716101926538011906_n-jpg
    Restoring My New MF 135-10509646_1440659139556235_6589859303160345860_n-jpg
    Restoring My New MF 135-10574238_1440659166222899_4900438824250098121_n-jpg
    In differential I found 1 liter of clean oil but that whose all. 25 liter where missing.
    I will flush it with 20L of diesel and then put new oil( ATF). I wonder how long it whose running without oil. :-(
    More photos and information soon.
  4. #14
    New Member
    Join Date
    Mar 2014
    Posts
    11
    Warsaw
    MF 135
    Yesterday I drain oil from gearbox and differential and made flushing with diesel. This is came out.
    Restoring My New MF 135-10599558_1440951772860305_6037230100341256739_n-jpg
    Restoring My New MF 135-10606185_1440951816193634_4387622265577840035_n-jpg
    After last drop of diesel came out I decided to open PTO cover to see what is inside.
    Good news is that it seems that everything is on its place but there is still diesel left in it. Today I will clean it use compress air to get it out of differential and put new oil. Below some new photos.
    I didn't saw that yesterday but now as I look at those picture I thing that pipe connecting pomp and cover is missing?
    If you see anything else please let me know.
    Attached Thumbnails Attached Thumbnails Restoring My New MF 135-10552492_1440953949526754_6218314122713318182_n-jpg   Restoring My New MF 135-10346112_1440953802860102_1644490095213599892_n-jpg   Restoring My New MF 135-10568880_1440953672860115_7539692451669449110_n-jpg   Restoring My New MF 135-10429380_1440953632860119_295462707179186548_n-jpg
  5. #15
    Join Date
    May 2013
    Posts
    1,066
    Norway
    Mf135, Ursus C-355, David Brown 995
    All the pipes are on the other side, and you mention ATF oil? as in automatic transmission oil? don't even think about it.
    Tractor universal oil or pure mineral motor oil 10/30 ot 10/40 works good.
  6. #16
    New Member
    Join Date
    Mar 2014
    Posts
    11
    Warsaw
    MF 135
    Quote Originally Posted by Agvg View Post
    Thank you for answer.
    I took of hydraulic selector valve (the one under the seat) and the pipe is there.
    Finally I used universal tractor oil that is for gearbox and hydraulic use. It is recommended for MF235 that is very similar tractor to 135.
    Unfortunately pomp is not pumping oil. I didn't have time to check why, maybe today I will have some time.
    I will try to open the PTO cover and the other one opposite side and I will make some photos. If I won't find anything I will remove top lift cover. It looks heave and I will try to avoid that.
  7. #17
    Gold Member Kenneth S's Avatar
    Join Date
    Jul 2012
    Posts
    348
    San Antonio, Texas
    1965 Massey Ferguson 2135 Industrial. 1967 Massey Ferguson 135. 1996 New Holland/Ford 6640
    The universal tractor fluid should be fine, never had any problems using it. You have to remember oil(s) has come a very long way since these tractors were built.
  8. #18
    New Member
    Join Date
    Mar 2014
    Posts
    11
    Warsaw
    MF 135
    Yesterday I take off the hydraulic respond cover and make photos.
    Restoring My New MF 135-20140826_201420-jpgRestoring My New MF 135-20140826_201435-jpgRestoring My New MF 135-20140826_201445-jpgRestoring My New MF 135-20140826_201450-jpgRestoring My New MF 135-20140826_201452-jpgRestoring My New MF 135-20140826_201503-jpgRestoring My New MF 135-20140826_202144-jpg
    I started to make a tool for taking off lift cover. Pleas let me know if you see something wrong. I will put more photos when I take off the lift cover.
  9. #19
    Join Date
    Jul 2013
    Posts
    587
    nz
    no tractor now
    I followed the link to your facebook page, the engine sounds good.
    Looking at the gearbox photos, the gears show only a very small bit of rust just starting ,so I think the gear box was not out of oil for very long before you got the tractor. Good luck.
Similar Threads
  1. Restoring my MF 65
    By claytonmesker in forum Massey Ferguson Owning/Operating
    Last Post: 09-18-2014, 05:17 PM
  2. restoring
    By wilsonfarm09 in forum Owning/Operating
    Last Post: 11-22-2013, 09:15 AM
  3. Restoring
    By Thomaslaplante in forum Farmall Vintage Tractors
    Last Post: 05-10-2012, 10:09 PM
  4. Restoring 8N
    By goosecreek in forum Parts/Repairs
    Last Post: 09-23-2011, 09:16 PM
  5. Restoring
    By revese in forum Farmall Vintage Tractors
    Last Post: 06-28-2011, 02:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
