Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    New Member jolas's Avatar
    Join Date
    May 2014
    Posts
    7
    Greece
    MF135
    Default
    Thank u Tom!
  2. #12
    Member
    Join Date
    May 2014
    Posts
    42
    Kovar, Texas
    MF 383, IH 444, MF 50C, CAT D69U B Farmall 3010 Kubota among others
    Default Re: Hi from Greece!
    3 pt leaking down is either piston seal or control valve. To check piston seal remove right side cover (some oil will escape) With side cover removed lift 3 pt arms and turn off tractor. You can see thru side cover hole if oil is leaking by piston seal. That tak sound you hear is relief valve during constant pumping.
  3. #13
    Join Date
    May 2014
    Posts
    7
    Greece
    MF135
    thanks MFIHCAT I hope I will not have to change the pump
Similar Threads
  1. hallo from Greece
    By thomastuning in forum New Member Introductions
    Last Post: 01-05-2014, 12:53 AM
  2. HELLO FROM GREECE
    By peppas in forum New Member Introductions
    Last Post: 08-30-2012, 09:59 PM
  3. Hi from Greece
    By Pefkias in forum New Member Introductions
    Last Post: 08-27-2011, 08:18 AM
  4. hello from greece
    By athanasios in forum New Member Introductions
    Last Post: 06-15-2010, 09:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
