botnaburrow
So we bought a nice looking Massey 135 gas with the z145 engine this spring and have been using it to plow, disc mow and till on our small vegetable farm this season.
Early in June we changed the oil (first time since owing the tractor) and found gas in the oil. We were befuddled and worried but after weeks of running it the problem didn't reoccur.
Then this fall we started having problems with the tractor running when discing a small field. The tractor would spudder and act like it was choked for fuel unless I pulled back on the throttle or took it out of gear. After a few time of throttling it down I basically can't keep the tractor running and can barely drive it back to the barn to park it. After changing the oil again we found some more gas in it and it seems like oil might be leaking out of the spark plugs? Seems really strange and we can't quite wrap out heads around it.
We replaced the filters checked the sediment bulb and gas tank. Next we are planning to pull off the carb for a soaking but maybe we are looking at a winter engine rebuild?
Anyone have and advice?
Thanks
Thanks
