bullmastiff
The hydraulics stopped working on my 1974 Massey Ferguson 135 (3 cyl Perkins gas, dual stage clutch, no multi power). I've had it for ten years with no problems. I haven't used the lift since autumn several weeks ago (worked fine then). The other day when it was really cold, the lift just wouldn't do anything. I checked the dipstick and it was milky brown--water apparently. I'm hoping that a fluid change will get it working again. I need it to take hay bales to my horses every week, so time is important.
I got the I&T shop manual, but it doesn't seem very helpful. I'm assuming I should change the filter while I'm at it, but I'm not sure if that's necessary. I'm also not sure if a filter change requires lift cover removal. I'm not sure that's a task I'm equipped for. I was hoping either I could avoid filter change by flushing with diesel or that I could access the filter for change through one of the side covers. I have non-professional experience working on cars several years ago, but I'm not experienced with tractors.
I'd welcome some guidance.
