gding287
Hey gang! As you see I have an MF35 (gas). We had a little snow storm and I pulkled out the blade. I notice the 3pt wasn't working but the pto is but only in engine mode it will not engage in ground mode. It feels as if the ground mode lever when depressed is hitting a non turning shaft. When the engine started I heard a loud clunk and can now hear a shaft wobbling in the case in the area of the seat right where the case split front and rear. There was no obvious over travel but the pto arms do lift freely when engine engaged and stopped. running and not runiing. I engaged transfer case and let pto run to try and warm the oil as its wuite cold. Fluid looks good an clear but a bit over where I usually keep it. (not sitting flat though)
My basic first question is there a known weakspot in a shaft that drives the hyd pump for the 3 point hitch lift mech?
2nd question what would be my starting point on plan of attack. All actuating arms feel they travel normal for trim and up/down. resistance is there.
Earlier symptom was every once in a while the engine pto handle would fall out of gear. Other that=n that shes a dream. I really want to get my eyes on that shaft and see what gave.
Thank you so much for your time. I really respect your alls passion and feel out of place by barging and and saying fix my stuff......lol. Im mechanically inclined and have a machinist backround so I am capable. Lost but capable...ty
