rnccen
I have a 135, the hydraulic / transmission was overfilled and run for about 1 hour with a brush hog. I went out and found fluid running out of the weep hole forward of the transmission and it appears that a large % of the UTF has gone.
I would appreciate some insight as to what are the likely solutions to what may have resulted or would I be safe to drain what ever fluid is left, put in 8 gallons of UTF and be ok?
1.) I read some posts about splitting a tractor to replace a seal....how can I tell if that is the cause of the fluid running from the weep hole?
2.) What are the typical rates to fix / replace the seal?
I have both the service manual and parts manual but am not prepared to personally split a tractor.
I am looking for constructive feedback please.
Thanks
Thanks
