MF204Mike
- Joined
- Feb 8, 2013
- Messages
- 52
- Location
- South Central Mo. USA
- Tractor
- 1960 Massey Ferguson 204 1954 Ferggie TO30 1966 Sears Custom, 1974 Wheel Horse B-80
I just bought a 1954 Ferguson TO30. Sweet little tractor. It had a few fuel leaks, needed new gasket at sediment bowl and a brass fitting where the fuel line connects to the carb. Fixed those for under $10.00. So now the only other "leak" I have is the seal at the PTO. I've already ordered the seal and housing gasket from E pay. should be here within the week. The housing for the PTO is broken and missing a nice sized chunk where the treads are if you wanted to use a PTO cover. My question is and maybe I should have asked in the Ford N section but since it's a Ferggie I thought I'd ask here. I looked on Ebay and found a few "used" complete PTO shafts with housings that are listed for TO 20, TO 30, and Ford N series tractors. However when looking closer at the housing ends it doesn't seem to be threaded to accept the PTO screw on cover. Does any one know if the Ford housings are in fact threaded.
Thanx in advance.
Mike
Thanx in advance.
Mike
