Syslogv4
I have a MF 135 with the Perkins diesel. The 3 point won't stay in the same spot when I'm bushhogging. It raises or lowers on its own. It also requires that the draft control is about half way before the position control will lift.
Next, the pto won't engage to engine when the tractor is on, but it can when it's off. It will engage to ground at all times.
Last, I was bushhogging and blew a rubber freeze plug on the left side. I put a new one in and then it blew the other one on the same side, rubber as well. The one I relaxed started backing out...
Any ideas?
Any ideas?
