Hi, just saw this thread
sorry for a late response.
Firstly, is the oil level sufficient? Also, is the correct oil in the gearbox and is its condition satisfactory? Be aware the gearbox oil is used in the hydraulic system. Any reading on its dipstick should be sufficient for it to operate. The dipstick is on the RH side cover, under the control quadrant. Check the oil with the tractor on level ground, and the engine stopped. If the oil is whitish-creamy colour, this usually means water contamination. A lack of sealing at the boots on the gear levers are the most common points of water entry. If the oil requires changing, lower the 3PT and if possible drain while warm ie after working for a couple hours, drain at both plugs overnight. Refill with SAE90 or 80-90 gear oil, Universal Tractor Oil or similar is also suitable. :thumbsup:
Secondly, are you using the lift correctly? Fully raise the Draft Control, and then control the lifting with the Position Control lever. This will allow it to lift to its maximum capacity, and allow you to control how high it lifts, where it stops, and it will then maintain that particular level by itself until the lever is moved again.
The pressure relief valve normally doesn't make a squealing sound - more of a hiss or squelch is likely. It seems this valve is positioned below the oil level. California is correct - tap into the hydraulics at one of the Allen-hex headed plugs at the sides near the front of the top plate, load up the lift arms and read the pressure.
Do you hear any type of clattering or clacking noise when it is trying to lift a heavy weight? This could simply mean wear in splined shafts, or broken pump mounting bolts which could be a bit of a mission to fix.
I can recall these tractors' 3PL being so strong that if the weight doesn't raise, the front of the tractor does. :laughing: But I need to realise these machines are now 50-60 years old, and could well need some TLC. I'm also getting into the same category! :ashamed:
Keep us informed - we all know that tractor should lift that implement with relative ease.
