HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Massey Ferguson > Massey Ferguson Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-15-2007, 04:06 PM   #1 (permalink)
New Member
Default GC2310 Tachometer Installation
Hello to all --
I've noticed some discussion on the forum here about the older model GC's not having a tachometer. That issue is probably the only one I have with my machine (2004 model) -- I really do like it a lot! But it seems silly for the operating manual to specify a certain RPM, and then have no way to determine whether you're at that RPM or not.
I asked my local dealer about adding one using MF components (I like the idea of using stock parts). The cost would be around $300. Bad enough to be sure, but what really made me decide against it was knowing I'd have to remove one of the engine covers and replace it with an updated version that would accomodate the tach drive.
The dealer recommended I check out a local auto electric parts supplier in the area. This I did, and was able to come up with a tachometer installation that I think is just as good as the new factory version -- all without having to open up the engine. Cost was just over $200, and resulted in a very smart looking dash (if I do say so myself).
The job wasn't all that bad. If anyone would be interested in details, let me know, and I'll post more pictures.
Rich
PA28150 is offline   Reply With Quote
Old 06-15-2007, 07:10 PM   #2 (permalink)
Default Re: GC2310 Tachometer Installation
Yes, I would be interested in knowing whose kit it is and where I can get one.
ray66v is offline   Reply With Quote
Old 06-15-2007, 09:42 PM   #3 (permalink)
Gold Member
archerynut's Avatar
good looking install, job well done!!
archerynut is offline   Reply With Quote
Old 06-15-2007, 09:44 PM   #4 (permalink)
New Member
I used a tachometer from ISSPRO -- their R8501 indicator, with R8906 sensor kit. I'd recommend this system to anyone considering the addition of a tachometer, because it uses a pair of small magnets to sense the rotational speed. You won't have to do any calibration (as you would if you were to tap the alternator). Just mount the magnets on the engine flywheel and you'll be able to measure RPM directly.
I don't know how widely available the kits are. I was able to purchase mine at a local supplier (Vineland, New Jersey) that deals quite a bit with tractors, as well as cars. I'm sure an internet search will be able to locate some ISSPRO dealers.
Hope this all helps!
Old 06-15-2007, 09:46 PM   #5 (permalink)
New Member
Quote:
Thank you! Feedback from my esteemed colleagues is most welcome (especially positive feedback!).
Old 06-15-2007, 09:49 PM   #6 (permalink)
New Member
Underside of the dash, with the tachometer
Old 06-15-2007, 09:52 PM   #7 (permalink)
New Member
One of the magnets, mounted on the engine flywheel
Old 06-15-2007, 09:56 PM   #8 (permalink)
New Member
Sensor location at front of tractor
Old 06-15-2007, 09:59 PM   #9 (permalink)
New Member
Underside of the dash, with the new wiring completed
Old 06-15-2007, 10:03 PM   #10 (permalink)
Super Member
kennyd's Avatar
You guys should check out the Tiny-Tach, at $65.00 it's the best deal for small engines.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.21137 seconds with 9 queries
