MrSteve
Gold Member
jeepcj7 said:It will only take you 5 - 10 minutes to replace the solenoid. Remove the 2 bolts, pull the solenoid straight out the back until the pin on the solemoid is fully exposed. Be careful not to damage the gasket. Reverse the procedure to install the solenois. 1100, 1200 & 1400 series had overide boot, 1500 series does not. When key is OFF, the solenoid will not let fuel pass thru. On earlier series, solenoid was energized by a capacitor for ~ 10 seconds to shut off fuel as soon as key was turned off.
Um I did that already (removed to test), look at my other post.
