Re: 1428 Hydro lockout woes
I have a 1428 hydro and have often stopped the engine while in gear. All I ever do is rock back-and-forth in the seat a bit while trying to move the gear shifter. She pops out of gear all the time. I have a lot of hills and this happens more times than I care to admit :) I never knew about the bypass and I'm glad I didn't.
I do wish there was a better way. Shifting should work regardless of where the tractor is. I thought I had read somewhere that this was just the way hydros were - it wasn't a MF thing but rather a hydro thing.
I have an AGCO St30x , identical to the 1428v and i do it all the time and have to rock back and forth and pull on the lever at the same time. I too would like to figure out some kind of fix for this.
Man, that problem sounds like a bummer. I am glad my Kubota B26 starts in gear. It has a lock out on the hydro-pedal that needs to be in neutral position but gearshift lever can be anywhere. It will also start without being in the seat although if the hydro pedal is pushed it dies. I like it that way. It is plenty safe for average users and allows me to crank it and move the backhoe levers from the ground which is handy as heck when changing out the bucket.
If I were in your predicament, I would maybe look at doing something like that to the MF so it would start in gear IF the hydro pedal was in neutral.
I have a 1423 hydro, an never had that problem. Sorry to hear about that.
