Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Silver Member mark4Jesus's Avatar
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    Massey Ferguson 1433v, 8X8 Synchro Shuttle trans.
    Default Turning in FWD
    Are there limitations turning when FWD is engaged? Can I turn the front wheels all the way without concern?
    Massey Ferguson 1433v, Bush Hog SQ600
  2. #2
    Veteran Member chh's Avatar
    Join Date
    Nov 2007
    Posts
    1,178
    Eastern OK
    MF 596 , MF 4243, MF 1433V, D4H, D3C
    Default Re: Turning in FWD
    Turning in FWD should not be a problem at all.
    Good judgment comes from experience, and a lot of that comes from bad judgment.
    Will Rogers
    The farmer is the only man in our economy who buys everything at retail, sells everything at wholesale and pays the freight both ways.
    John F. Kennedy
  3. #3
    Join Date
    Nov 2007
    Posts
    220
    Salem, Oregon
    On many of our tractors, the front wheels "land speed" is slightly faster than the rear just to address turning.
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by chh
    I would add this to that reply:
    if the tractor is on gravel or dirt.
    The front wheels do turn slightly faster, and need to be able to "slip" a little, you can also feel a binding when turning hard because the inside a outside wheel are rotating at different speeds.
    If you are on hard pavement where the tires can't slip a little then you can damage your tractor!
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Feb 2008
    Posts
    1,854
    Orstraya , Ex convict stock , G'day .
    Don't use the turning brakes when in FWD .
  6. #6
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    Thanks guys. I had never give it any thought until the other day when I was doing some disc-ing and noticed how sharp the front wheels turned at full left/right turn. I blew a drive shaft seal on a kubota I used to have by leaving it in FWD and running down the road in 4/High, so I am always looking out for the FWD.
  7. #7
    Join Date
    Nov 2007
    Posts
    1,178
    Eastern OK
    FWD just really isn't meant for fast road driving. I looked at a used MF 481 last year that I don't think had ever been out of FWD. The axle seals where leaking and the front tires where worn out in under 500 hrs. The owner had property on a paved county road and ran field to field on pavement.
    Will Rogers
    John F. Kennedy
  8. #8
    Platinum Member DEWFPO's Avatar
    Join Date
    Jun 2007
    Posts
    917
    "High in the Rockies"
    2009 Bobcat Toolcat 5600 D
    Quote Originally Posted by kennyd
    A picture is always worth a thousand words to me. DEWFPO
    Attached Thumbnails Attached Thumbnails Turning in FWD-tirepathsinaturn-jpg
    2009 Toolcat 5600 "D-Series", Hi-Flow, 29's, 72" SB-200, 84" Snowblade, 62" Lo-Pro Bucket, Titan HD 48" Pallet Forks
    SOLD - 2006 MF GC2300, 2350 FEL, 2315 MMM, 2360 SB, KingKutter CarryAll
  9. #9
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Quote Originally Posted by DEWFPO
    That is very cool! Thanks for posting
    Mind if I save that to use in the future?
    KennyD
    www.boltonhooks.com
  10. #10
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    DEWFPO, great picture! I like pictures, easier than reading!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
