Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Sep 2008
    Posts
    12
    Default 1997 MF 240 problem with frontend loader
    I tried to use the frontend loader to pick up the front end to change a flat tire in the field. When I got the tires off the ground, I let the loader handle return back to normal postion and the loader just let the front end fall back to the ground would not hold its position. I do not notice any leaks any where. The pump is on the back of the seat on the left side. Does anyone know if the pump could be the problem and if so are they hard to rebuild? Many thanks in advance, Gator3.
  2. #2
    Platinum Member MFRED's Avatar
    Join Date
    Mar 2006
    Posts
    797
    Connecticut
    MF 5435, MF 165's
    Default Re: 1997 MF 240 problem with frontend loader
    Doesn't sound like the pump. More of a control valve or an internally leaking cylinder. Does the loaer leak down when raised also?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
