Need Help Please !!!! MF 50? industrial
   / Need Help Please !!!! MF 50? industrial #1
Terry T
Niagara Falls, Canada
Ford 8N & Massey Ferguson Industrial
I have no clue about this tractor only that it followed me home last week. You know the deal that is too good to be true. Anyways my problem is "what is it?" and what is the fluid that it used for the "shuttle shift?" I was told reg. trans fluid? and for the perkins 4 cylinder engine, what filters or service info is out their? Thanks for your time and help.
Terry T (Niagara Falls, Canada)
   / Need Help Please !!!! MF 50? industrial #2
I looked at tractordata.com but they don't have much info listed about industrial tractors. They have the models listed just no info. I'm sure Farmwithjunk will probably be able to help you out on this one. Look for any tags with serial / model #s.
Serial plate says 9A 97639 but no one has that number listed? The cab is a after market i found out , MF didnt make cabs then? Im starting to think I made a mistake in letting this tractor follow me home. My wife keeps saying " stop bringing home all the strays". Thanks for your help.
Thanks so much, i so want to start working on this tractor butfirst things first. Owners manual, so many filters so little time. Then what type of fluid does a shuttle shifter take, leaked most of it out and hard to stear as well. Big and ugly but with a little love, and some paint it will be as pretty as my 8N. Thanks again for your help, i check this site 2-3 times a day waiting for some one to help me.
Terry T
(Niagara Falls Canada)
   / Need Help Please !!!! MF 50? industrial #6
Trans and Diff Extreme pressure Transmission oil Conforming to Massey
Ferguson Spec # M-1129 Filters Napa or Massey dealer can match up
   / Need Help Please !!!! MF 50? industrial #7
I have a 30E A little smaller machine . Industrial TLB shuttle shift .
The transmission takes MF Permatran III. There are any number of cross over oils. Just read the can and look for Permatran III. It is not straight hydraulic oil. My machine takes almost 15 gal between transmission and rear end. This spring I will do the 1000 hr change for the first time and I never expect to do it again. I know a fair amount about the machine , yours is older I think but maybe I can help. MF ag is now owned by Agro. MF industrial is owned by Terex. The local MF ag dealer here told me he can get me any parts I need.
   / Need Help Please !!!! MF 50? industrial #8
picture of mine
   / Need Help Please !!!! MF 50? industrial #9
The transmission takes regular red automatic transmission fluid.
If the steering is stiff look on the right hand side of the engine at the front and see if there is a small pump driven by the fan belt, this will be the power steering pump if it has one fitted. Turn the steering wheel one complete revolution to the left, remove the filler cap and check the fluid level in the steering pump reservoir, it should be filled to the bottom of the neck with the same red transmission oil.
It is a long time since I worked on a MF50 so I can't remember the filter numbers but you should be able to take them out and have them matched up at a filter suppliers.
   / Need Help Please !!!! MF 50? industrial #10
Good call, Paul. That usually cures heavy steering in our MF50 Industrial.
It's been a good starter, after some kids left the tank cover open and we got a dose of water through it and that upset the pump.
Also, I'm about to fit a front end loader to ours. It's from a Ford 5000 industrial and on the Ford, the main pump was driven from a tlke off in the bellhousing and a driveshaft ran along to the pump behind and to the left of the driver's seat. I suspect the MF 50s used a front mounted pump, probably driven through the hole in the front axle pivot.
Can anyone confirm that, please? Also. where was the hydraulic tank located?
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
