here are some pics of bagger, and rankin toothbar and thumb welden on.. Yes the bagger by humbolt not cheap about $2100. Does a nice job but in the process of having a problem worked out. The one for the gc2410 come with a adapter bracket that bolts on with U bolts and this is where you attach the 3 point pins. The bags rub on the brackets causing the bags to tear after one or 2 uses. If you switch the brackets around the way they should be, the
pto shaft is about 3 " to short. So in the process of having a new shaft made . Dealer is helping me out..Wonder if massey knows about this problem as they deal with humbolt for there bag system. Have replacement bags but still using old until problem fixed. Ray
