HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Massey Ferguson > Massey Ferguson Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-16-2009, 04:12 PM   #1 (permalink)
hd5
New Member
Default 135 hydraulic linkage
My 135 has quit lifting a heavy load. It will pick the arms all the way up empy, but with a bale of hay it rises very slowly and only about a foot.
If I remove the inspection plate on the right and move the position lever upward the vertical lever will only move the pump lever (the one with the roller) a short distance. If I use my finger I can move the lever toward the rear of the tractor and it raises quickly and smoothly. I am not able to see if it will do that under a load though.
Also if I move the positon lever to constant pumping it does not cause the relief valve to pop, I think it used to.
If I manually move the pump lever the relief valve pops.
It seems I am out of adjustment , I assume the lift cover needs to come off, I have done it before, don't like it.......
What do I need to adjust?
Thanks
hd5 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.12895 seconds with 8 queries
