HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Massey Ferguson > Massey Ferguson Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-07-2009, 03:33 PM   #1 (permalink)
New Member
Default GC2300 engine stops when I turn lights on
Anyone have any suggestions... When I turn the headlights on while the engine is running, engine immediately cuts off. I can turn the hazards and turn signals on with no problem. If the engine is off and I turn the power only on, the headlights and taillights work fine. I checked as many connections as I could locate and everything seems fine. Thanks for any help.
hollywd is offline   Reply With Quote
Old 11-09-2009, 05:55 AM   #2 (permalink)
irvingj's Avatar
Default Re: GC2300 engine stops when I turn lights on
Wow, that's a head scratcher! Sounds like the fuel cut-off solenoid may be dropping out... any way to verify that, as a starting point?
Please keep us posted!
__________________
'07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb
'05 VW Jetta Wgn TDI
Numerous antique Japanese motorcycles
irvingj is offline   Reply With Quote
Old 11-10-2009, 08:25 AM   #3 (permalink)
Gold Member
MFRED's Avatar
Yes, check connections. Something must not be getting a good connection. Grounds maybe. I can hear that call,"no, really it shut off when I turn the lights on!"
MFRED is offline   Reply With Quote
Old 11-10-2009, 05:46 PM   #4 (permalink)
The fuel cut off solenoid requires a minimum level of amperage to keep the fuel flowing. I suspect that turning the lights on is reducing the amperage available to the fuel cut off solenoid.
Have you tested the battery and alternator?
The fuel cut off solenoid recently failed on my B21. Before it failed it started using more and more amperage which was demonstrated by blowing fuses.
BruceWard is offline   Reply With Quote
Old 11-11-2009, 10:27 AM   #5 (permalink)
New Member
I know the battery is in good shape. I'm not sure how to test the alternator though, any advice?
Yeah, I'm sure that will be a fun call to make. "No really, I'm not drunk, it really does turn off when I turn the lights on"...
Old 11-11-2009, 01:50 PM   #6 (permalink)
Labrat's Avatar
Check the voltage at the battery with the engine off should be 12 to 12.5. Start the engine and check output should be 13.2 to 13.6. If it isn't check the output at the alternator stud. If that doesn't read 13.2 or higher you have no alt output. Possibly alternator, Regulator or what ever they use to excite the alternator like a charge light bulb.
__________________
If you pour a gallon of knowledge into a shot glass of a brain; you’re going to spill some. “Bud Bundy”
Labrat is offline   Reply With Quote
Old 11-11-2009, 03:33 PM   #7 (permalink)
J_J
Super Member
J_J's Avatar
Do you have an electrical schematic of your tractor?
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 11-14-2009, 10:49 AM   #8 (permalink)
New Member
I don't have a schematic of the tractor. Any idea how I can get one?
Thanks Labrat, I'll give that a try.
Old 11-15-2009, 09:00 AM   #9 (permalink)
irvingj's Avatar
Not real clear, but maybe this will help--
gc2300-engine-stops-when-i-wiring-1.jpg  gc2300-engine-stops-when-i-wiring-2.jpg  gc2300-engine-stops-when-i-wiring-3.jpg
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.19059 seconds with 9 queries
