porky69
- Joined
- Jun 28, 2007
- Messages
- 105
- Location
- Coaldale, Alberta, Canada
- Tractor
- 2009 Massey Ferguson GC2400
If I wanted to add an extra hydraulic circuit or two to my GC2400 how would be the best?
I looked at a GC2410 on a dealer lot figuring that the backhoe hook up would be about the same as auxiliary spools but it was cold, wet and snowy around the tractor so I couldn't get a good look.
I seen that one hose comes from the loader valve block (I assume this would be a pressure line) but couldn't see which port it hooks to (I see there are 3 rubber hoses coming out of the valve block on my GC2400). Does anyone know which one it is?
I would assume it hooks to a power beyond port, which if I understand hydraulics right would also be going to the 3pt hitch controls. If it is going to the 3pt hitch could I just put a tee inline and have the original hose go to the 3pt and a second line to my auxiliary valves?
I did see that the other hose goes to a fitting on the right rear side of the differential housing, I found this one on my tractor and see there is already a port there with a plug in it. I would assume this is the return line.
Am I on the right track? Any help would be greatly appreciated.
