Results 1 to 6 of 6
  1. #1
    Gold Member Paystar's Avatar
    Join Date
    Nov 2008
    Posts
    336
    Ontario, Canada
    Default Front Quick Attach
    Hello all. I just saw a post on a JD forum documenting with pics the procedure (on a 2305) on how to go from front mounted implements like a blade or blower, back to fel use. Can anyone tell me what is involved on the Massey GC. How big a deal to switch from front attachment to fel? Is everything just pinned on, or do you have to unbolt stuff?
  2. #2
    Gold Member massey driver's Avatar
    Join Date
    Aug 2009
    Posts
    408
    north of winnipeg canada
    massey 175,1655,gc2300
    Default Re: Front Quick Attach
    Quote Originally Posted by Paystar View Post
    I can tell you this it's all pinned on and to go from one to the other it doesn't take much time at all.Under 15 minutes.It all depends on you and what you do.You can take the blower/blade off and leave the quick attach on and put the loader on.One downside to this is you don't have as much clearance. My advice is take the quick attach off less chance of doing any damage to the pto shaft under the tractor or to the quick hitch itself.Larry
    Massey Driver Larry
    MF 175 Diesel, MF GC2300 Diesel,Kubota BX 2350 diesel
    Many different one's over the years but still driving Massey.
  3. #3
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Hey, Paystar--
    Ditto Massey Driver: 15 min +/- to go from FEL to front-mount blower or the other way around, for me. Not a problem. Also about the clearance with FEL use and the quick-hitch still on...doable, but loss of clearance under the front. See other threads on same subject.
    The only "unbolting" is for the grille guard on the 2310, which has to come off to use the quick-hitch. Don't know about the 2400/2600 series. I just take mine off in the fall (for snowblower operation), and leave it off 'til spring, when I switch back to FEL/backhoe and mower deck use.
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  4. #4
    Join Date
    Nov 2008
    Posts
    336
    Ontario, Canada
    Hello, thanks for the answers. I remembered reading about someone using his fel with the quick attach still on, but I couldn't find it. It's hard searching through all the posts when you're stuck in dial-up **** like we are in this area I tried one of those internet sticks and it didn't work here either. Heck I can't even get signal on my Garmin GPS. I must be in a cave
    Ya, I saw the changeover procedure on the JD and wanted to see if it was as easy for the GC. I was thinking before, the 3 pt. snowblower would be better for me....now I'm not so sure. I'd rather go forwards!
    Take care.
  5. #5
    Gold Member Jaylegger's Avatar
    Join Date
    Oct 2009
    Posts
    454
    Massey Ferguson GC2600L
    Just in case there''s any question, the quick attach subframe can be removed from the tractor much quicker than it takes to remove or install the loader and about the same or less than the attachments the quick attach is designed to carry. When I removed the quick attack subframe after the snowblowing season this year I found the simplicity of the procedure rather remarkable.
    Nightime snowblowing in rain.
    http://www.youtube.com/watch?v=yp50hn8lHf8
    _______________________
    MF2360 Front Snow-blower, 60" MF2340 front blade/Hydraulic angle, Woods BH6000 backhoe, Land-Pride GS1548 Grader/Scraper, 54" 2315 Mulch Mower, DL100 Loader
  6. #6
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Paystar-- removing blower & quick-hitch:
    1. Unlock locking lever by flipping up, after removal of lynch pin safety.
    2. Disconnect hydraulic lines (2) and electric feed --for chute controls-- if necessary.
    3. Slide blower off front, using a dolly w/rollers
    4. Remove mid-PTO driveshaft (quick-disconnect at rear).
    5. Loosen large "T" nut at front of quick-hitch.
    6. Tilt forward, lift, and remove quick-hitch assembly. (It just "hangs" on front of frame.)
    That's it; about 6-7 minutes, if you're slow like me!
    FEL operation does not interfere at all with the quick-hitch assembly, but the Q-H does hang down pretty low on the front.
    Attached Thumbnails Attached Thumbnails Front Quick Attach-q-h-lock-lever.jpg   Front Quick Attach-sliding-off-shoe.jpg   Front Quick Attach-q-h-t-bolt.jpg   Front Quick Attach-quick-hitch-installed-2.jpg
Similar Threads
  1. Differences in Quick Attach Bucket Mounts?
    By Dougster in forum Attachments
    Last Post: 10-22-2012, 06:06 PM
  2. Lifting Capacity of the Front Mount Quick Attach
    By niedejb in forum Kubota Owning/Operating
    Last Post: 03-10-2010, 05:51 AM
  3. quick attach bucket question
    By shiggy in forum Attachments
    Last Post: 12-11-2006, 09:53 PM
  4. FEL bucket conversion to a Quick Attach???
    By Bob_Skurka in forum New Holland Owning/Operating
    Last Post: 09-27-2004, 02:29 PM
  5. ATI "pin type" Quick Attach for NH, Kutota, Case?
    Last Post: 07-04-2004, 06:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
