TO 30 Sediment Bowl
   / TO 30 Sediment Bowl #1
BKBrown
Gold Member
Madison, VA
Ventrac 4231 Gas
Did some work on a Neighbor's TO 30 and replaced the Sediment Bowl with a new one.
It was fine for a while and has now started to leak around the gasket. This is a rubber gasket and I am wondering if the ethanol in the gas has affected the gasket.
Has anyone else had a problem with this and if so - have you found a solution ?
Thanks in advance.
   / TO 30 Sediment Bowl #2
I have a Ferguson TO-35, and I bought a new sediment bowl assembly and fuel shutoff from Tractor Supply. It's made in China, and is a total piece of junk. Nothing is right, and I do mean nothing. If you want a good gasket, make one yourself from rubber impregnated cork , or a rubber sold for ethanol fuel. Be certain there is no brass wire filter disc to get in the way of the gasket sealing. And if the bowl was made in China, it's probably not flat on the sealing surface.
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
Electric Mobility Scooter (A51694)
Electric Mobility...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 KENWORTH T800 DAY CAB (A53426)
2015 KENWORTH T800...
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
