dieselwiezil
- Joined
- Nov 21, 2010
- Messages
- 4
Im working on a 265 that he lift arms are not working correctly. The will not raise when you pull the lever. I really think the problems has to do with the way the valve are oriented. Basically what I need to know is how do all the different levers need to be arranged to make the 3pt hyd work. If you have the valve pulled back to where they should raise, they will raise about an inch and stop but then if you let it sit running for 15-30mins they will raise up a little bit. I really dont think there is an issue as far as the pump goes, just the way the valves are set. Any IDEAS? Not very familure with MF, but always willing to learn. Also a hyd schematic would be great if anyone has one.
