Results 1 to 5 of 5
  1. #1
    Join Date
    May 2009
    Posts
    52
    Bancroft Ontario
    Massey Ferguson MF 250, Belarus T-40A
    Default '58 MF-50 Issues
    Hey all, I was just outside putting the blade on my old MF 50, when I lifted the blade and put it in gear to plow the driveway I let the clutch out and BANG. That was it. No movement. The hydraulics and PTO still work. I'm thinking it's the rear driveshaft but I don't really know. Any suggestions? I need to get it up and running ASAP before it snows again
  2. #2
    New Member Fahmahdave's Avatar
    Join Date
    Feb 2009
    Posts
    18
    Mid coast Maine
    Massey Harris 50
    Default Re: '58 MF-50 Issues
    I've got a 1956 MH50. Can you shift the transmission into all gears? Hi-Lo sick too? It sounds like the final drive portion is the problem is can shift to all. Mine has had problems in the past getting stuck in 2nd gear or in neutral. I've always managed to free it by taking the top plug out on the tranny and moving the sliding gear the the stick attaches to. Good luck!
    A bad day working outdoors is better than an excellent day working behind a desk........anytime!
  3. #3
    Join Date
    Apr 2008
    Posts
    206
    NY
    MX5100HST FEL, KX121 MINI X
    I did something similar on my 165. You may have locked the transmission there was a good read up on this on the web somewhere Ytmag.com has good info on the older tractors. When this happened to me it would start but when of clutch would stall, be careful you can break something in there
  4. #4
    Join Date
    Nov 2007
    Posts
    194
    Northeast USA
    1955 Ferguson TO-35
    I assume it wasn't just the dual range transmission lever popping out of gear, was it ? ( Yes, as a matter of fact that hapened to me shortly after I bought my Ferguson, and I was very upset until I realized what the trouble was.)
  5. #5
    Join Date
    May 2009
    Posts
    52
    Bancroft Ontario
    Default
    Thanks for the help. Turns out i was right, sort of. Theres a grooved sleeve in the rear axle driveshaft that is designed to function like a shearpin and that's where my troubles manifested themselves. Also found that he clutch was in perfect condition other than 53 years worth of wear. And dual stage clutches are ridiculously expensive
Similar Threads
  1. Oil & Fuel MF 50 diesel engine problem
    By misterme in forum Massey Ferguson Owning/Operating
    Last Post: 07-18-2009, 11:12 PM
  2. From MF to Kubota B2920...
    By Tompet in forum Kubota Buying/Pricing
    Last Post: 06-19-2009, 01:01 PM
  3. Help identify my fathers Massey
    By Willl in forum Massey Ferguson Owning/Operating
    Last Post: 10-23-2006, 03:15 AM
  4. NH Class II Warranty Issues (Fast Help Needed)
    By Spencer in forum New Holland Owning/Operating
    Last Post: 03-03-2004, 04:13 PM
  5. Review and Issues
    By nater in forum Power Trac
    Last Post: 09-05-2002, 07:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
