MF 165 lift issues
   / MF 165 lift issues #1
SB farm guy
SW Vermont
massey 165
I am new to this site, have a Massey 165 built in 1971 (England) with 212 Perkins diesel. New to me but well used. Everything seemed to work when we looked at it, but lift arms shake, and won't lift my drum mower, will lift lighter items (5' tiller) if throttled up.
I have seen older threads that point to pump valves/pistons, leaky lift cylinder, etc with these symptoms. Have not seen definite answer to if tractor must be split to rebuild or replace these parts, assuming more mundane things like filter aren't the problem.
This tractor has multipower.
I am ordering manuals but would like to have some idea what I may be getting into.
I would appreciate any help that is out there.
   / MF 165 lift issues #2
Photos are of my 135 when I had similar problems. O-rings on the lift rod from the pump / over-greasing lift arms that contaminated my hyd fluid and clogging the filter were what caused my problems. Lesson learned for me, one pump of the grease gun will do .... :thumbsup:
Thanks much. I hope it turns out to be basic maintenance, and not a major project, although pulling the cover does not look like a routine item. 135 is a nice machine, my father in law has one.
   / MF 165 lift issues #4
Will it hold the weight up if the tractor is turned off? I bought an older Deere with similar issues a while back. Mine would bleed off immeadiately when the tractor was shut off. I replaced the valves and seats for the 3PT and it works great now. Not sure if that's your problem, but it might be worth considering.
There shouldn't be much in the 3PH lift which would require splitting the tractor. The pump should be attached to the engine, 3PH control valves should be in the cover on on the side of it, lift piston should be in or under the transmission cover.
Does bleed off slowly. Only concerned because multipower hardware makes pump too large to come out top cover for rebuild (as I understand it). Probably don't have that totally right, thus my question.
I am banking on the manuals making me smart enough to deal with it, since I would be lying to say I understood it very well right now.
Needless to say I am starting to hear about the tinker toy I bought...
I do love a challenge.
   / MF 165 lift issues #6
Even after replacing orings on the standpipe / flushing twice and installing new filter / checking lift piston and adjusting tolerances my MF will not hold the arms up after shutting her down. From what I've been told over the years that is a characteristic of the older masseys.
Lift piston and rod, along with linkages are attached to the cover, which is probably why it weighs 2 million pounds (definitely a two person job).
I have read that over and over about the weight. I could live with dropping after shutdown, but really need to lift properly. 800 # mower should be no issue, my compact 1250 is up to it. On the good side, if I rebuild it right may last another 40 years.
   / MF 165 lift issues #8
Pulling the lift cover is not a complicated task, there is a roller that when you take the side cover off you will see, you have to remove it to slide the linkages apart during removal.
Installation is where you have to be careful to get the linkages situated correctly. Even with the I&T manual I still took some photos, a picture is worth a thousand words.
As mentioned in previous post, if like me you don't have another tractor with a FEL or a come-a-long / lift of some sort, be careful because most of the weight is towards the aft end of the lift cover. I did drain the oil from mine because of contamination, to simply remove the side cover to access the linkages you would probably get away with approx 10-15 litres (2-3 gals).
   / MF 165 lift issues #9
First thing I would change is the filter, my first post with pictures, second and third images show the filter next to the PTO engagement lever cover, pop that off and it's right there. You can see that mine was lockwired, as it should be it was only hand tight, 30 minute job tops so worth doing for sure.
Should definitely lift 800 pounds, my problem is normally keeping the front end from coming off the ground if I've gotten a little reckless and chained a 26 inch 14 foot white pine log onto my 300 pound 7 foot back blade.
I will start with that. Thanks much for the help. Looking forward to the manuals. Thanks also for the photos, really helps to anchor the information. I will fire back an update in a week or so after I have had a chance to open her up.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
