Results 1 to 5 of 5
08-16-2011, 11:45 AM #1New Member
- Join Date
- Mar 2011
- Posts
- 13
- Tractor
- MF 285
285 Mf Charging trouble
My old 285 Mf is causing me some trouble . Replaced battery and alternator . Amp meter only show a charge after running throttle wide open ( but not always ) is there a pressure switch connected to the charging circuit ? If so where is it located . Part number for replacement
08-16-2011 11:45 AM # ADS
08-24-2011, 11:14 AM #2
Re: 285 Mf Charging trouble
08-27-2011, 12:56 AM #3Member
- Join Date
- Jan 2009
- Posts
- 47
- Location
- north carolina
- Tractor
- MF 35, 135, 255, 20 Ind., 5455
There is a pressure switch mounted on the oil pressure guage. when oil pressure comes up this activates your electrical system the same as turning on an ignition switch on other models. If your fuel guage and tempature guage are working this switch is not bad. If this is the case it points to the exciting diode.
08-27-2011, 09:56 AM #4New Member
- Join Date
- Mar 2011
- Posts
- 13
- Tractor
- MF 285
Thanks for the info . have been trying to find a wiring diagram with no luck . The temp gauge and the fuel gauge are both working . Will pull the dash and have a look . Thanks
08-27-2011, 11:35 PM #5Member
- Join Date
- Jan 2009
- Posts
- 47
- Location
- north carolina
- Tractor
Look on the end of the alternator and you will have 3 wires. Get a jumper wire and touch it to the battery post on the alternator(the big wire) and to the wire in the plastic connector that is marked # 1 while the tractor is running and this should excite the alternator to charging and it will charge until you cut the tractor off or the battery reaches full charge. If this is the case either the wire coming from the oil pressure switch to terminal # 1 on the plastic connector on the alternator is broken or disconnected or the exciting diode which is in this wire is bad. you can use the jumper wire until you have time to trace the wiring.
Similar Threads
New Member with MF 240
By Cold Beer in forum Parts/RepairsReplies: 1Last Post: 05-04-2010, 01:27 PM -
Buying Advice Grand L vs. MF 1600 Series?
By Yankee in forum Kubota Buying/PricingReplies: 14Last Post: 03-27-2010, 06:26 PM -
Should I bargain with dealer on a new MF 1648??
By Woodcanoeguy in forum Massey Ferguson Buying/PricingReplies: 3Last Post: 03-07-2010, 08:25 PM -
need help deciding: MF vs Mahindra
By bludev in forum Massey Ferguson Owning/OperatingReplies: 14Last Post: 01-30-2010, 12:35 AM -
MF 1030 with FEL or Yanmar 2620D?? Things to consider on purchase
By longrange2 in forum Buying/Pricing/ComparisonsReplies: 4Last Post: 02-26-2007, 07:03 AM
