Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Dec 2011
    Posts
    12
    Ferguson TO30
    Default Ferguson TO30 w/ John Deere #412 Plow, overmatched?
    Hello Friends,
    I have a Ferguson TO30, and was given a John Deere #412 2 bottom plow. The TO30 will pull it, but the plow seems a shade too big for this tractor. The front coulter will bump into the sway bar chains if its not perfectly centered, and it wants to sway to the extreme right no matter how I adjust the draw bar/land slide/etc.
    Is this plow just too big? What is a good 1 or 2 bottom plow match for a TO30? Has anyone else successfully used this combo? I am in West Michigan and the clay here is like glue.
    Cheers,
    Bob
    Attached Thumbnails Attached Thumbnails Ferguson TO30 w/ John Deere #412 Plow, overmatched?-photo-jpg   Ferguson TO30 w/ John Deere #412 Plow, overmatched?-photo-1-jpg
  2. #2
    Join Date
    Jul 2003
    Posts
    1,930
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Default Re: Ferguson TO30 w/ John Deere #412 Plow, overmatched?
    Quote Originally Posted by Bob Senti View Post
    Hello Friends,
    Cheers,
    Bob
    Take the front coulter off...we used to plow at least 40 acres a year without one...also the "points" or shares most likely need to be replaced....the front one has a welded piece (not original) on it and unless its pretty "sharp" will hinder good plowing...JD still sells the shares for that plow (I'm pretty sure...). Most folks thought the JD plows were like sinking a ship's anchor into the ground complared to Dearborns or Oliver plows.. if the ground isn't too much clay you should have no problems once you set it up right, though. BobG in VA
  3. #3
    New Member
    Join Date
    Dec 2011
    Posts
    12
    Ferguson TO30
    Thanks for the quick response Bob!
    I forgot to mention Im in West Michigan, and alas, its heavy clay!
    Im thinking then I probably need to drop down to a one bottom for these conditions and this size tractor?
    The picture is bad (share full of clay!) - the shares have no welds. Here is a better close up shot of the share all cleaned up. They both look the same.
    Taking the coulter off would definately give me better clearance. I will have to try that, although I wonder about trash gumming up on it (I am trying to plow an old grass pasture).
    Cheers,
    Bob
    Attached Thumbnails Attached Thumbnails Ferguson TO30 w/ John Deere #412 Plow, overmatched?-photo-1-jpg
  4. #4
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Hello Friends,
    Cheers,
    Bob
    Do you have it adjusted correctly? The way it looks in the picture, it should push to the left as it throws the sod to the right. I'm no farmer so i couldn't begin to tell you how to adjust it.
Similar Threads
  1. John deere 3 bottom trailer plow
    By Amaricanfarmer202 in forum Attachments
    Last Post: 07-13-2011, 12:43 AM
  2. JD855 = YANMAR what?
    By JD855 in forum Parts/Repairs
    Last Post: 01-13-2010, 01:18 AM
  3. John Deere 2210 with Curtis Hard Sided cab
    By ctc1111 in forum Customization
    Last Post: 05-01-2009, 07:11 PM
  4. New Massey Ferguson 1532 or used John Deere 3320
    By WH401 in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2008, 10:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
