Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 54
  1. #41
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Default Re: GC Series Owner Upgrades And Modifications
    Wow, Ray, I really like that idea... not too many watts, and saves $4+/gallon diesel fuel!
    What did you use to "glue" it on with? I see where it comes with adhesive, but it looks like you added something there...
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  2. #42
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    GC2310, Toro Reelmaster 5100D
    Quote Originally Posted by irvingj View Post
    There is silicone sealer around the edge, which is usually included in the kit.
    It takes longer figure out where to route the cord than to install it.
    These also come in lots of different sizes, for all kinds of applications. You could install a larger one for faster gratification. I decided I would rather go smaller, and be able to leave it turned on.
    I have decided to add a 25 watt model to the engine oil pan, I will let everyone know how that worked out.
    We used similar units on airplanes for years.
  3. #43
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Interesting, Ray... does that mean it could warm up my O-320? All the engine heaters I've been perusing so far are mucho --scary-- bucks. If something like Northern's stick-on could work that would save a ton of money!
    Walt
  4. #44
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    Walt
    Yes. Of course, you get robbed because of the STC.
    E-Z HEAT A/C ENGINE PREHEATER from Aircraft Spruce
    These are sized to be used for an hour or two, and then you go. Some caution that leaving them running for long periods of time, can "potentially" cook the oil.
    The issue with an O-320, is the significant amount of oil that is in the oil cooler would not get warmed. I prefer to preheat with a torpedo heater into a manifold, made from furnace pipe. Then, everything gets warmed.
  5. #45
    New Member
    Join Date
    Mar 2012
    Posts
    21
    Houghton, MI
    Tractorless
    How did the oil pan heater work out? I just ordered one myself...
  6. #46
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    Sorry, I forgot I promised to get back on that.
    Yes, it is installed, and was very easy. Clean the pan, stick it on, calk the edge.
    It did not come with silicone to seal the edge with, so you should have some available.
    I have not actually used it yet, beyond plugging it in to warm it, for installation.
    You will be surprised how fast it gets hot.
  7. #47
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Hey, Ray, that's good to hear. I haven't gotten around to installing mine yet... still have the MMM to remove, service, and put away!
    When you mentioned a "torpedo heater" with stovepipe duct... you mean one like this? I had it for temporary heat in my garage, but now it just sits around --stored-- now that I finally have a more permanent solution to garage heat. I hadn't thought of using it for O-320 heat. It would be great to find a use for it! I suppose it would be safe as long as it was several feet away from the engine? Walt
  8. #48
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    Click image for larger version.
Name:	Mr. Heater.JPG
    I will send you a PM.
  9. #49
    Platinum Member cdaigle430's Avatar
    Join Date
    May 2010
    Posts
    771
    Maine
    MF GC2410
    Nice Ray66v
    2010 MF GC2410 TLB, 2006 Husqvarna YTH 2448, 2004 Honda Rincon 650, 2007 Honda Shadow Aero 750, 2006 Jeep Grand Cherokee Limited-Hemi.
  10. #50
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Thanks, Ray, got your PM and printed up your "directions". Also found no filter on the vacuum intake, so I'll be installing one of those, too.
    Finally got the MMM off and it's greased, but the blades still need to come off to be sharpened. In the middle of winter-prep stuff on the vehicles now; just got my new snows, but have to replace a rear hub/bearing on wife's AWD Matrix. Fun. (Old. Rusty. Stubborn. You know the drill....)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
