Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    8
    huntsville, AR
    massey ferguson 90
    Default 90 massey ferguson firing order
    Can someone tell me about 90 massey ferguson propane motor? since purchase we haven't been able to find out anything such as firing order. any info would be really appreciated.
  2. #2
    Member
    Join Date
    Aug 2011
    Posts
    42
    NE TENN - CENT FLA
    massey ferguson 255
    Default Re: 90 massey ferguson firing order
    99.9% of all in line 4 cylinder motors is 1342 and 6 cyl. is 153624
    1977 massey 255 w cab 7 ft bush hog 6 ft box blade bush hog 330 FEL small back hoe
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    8
    huntsville, AR
    massey ferguson 90
    thanks for info. can u tell me about adjusting valves on 90 massey propane 4 cylinder motor?
  4. #4
    Member
    Join Date
    Aug 2011
    Posts
    42
    NE TENN - CENT FLA
    massey ferguson 255
    I don;t have the lash spec but there is an easy to set them. turn the motor the direction of normal rotation, on each cylinder watch the valves, as the exh fully closes set the intake and as the intake just starts to open set the exh.
    Quote Originally Posted by painthorse2 View Post
  5. #5
    New Member
    Join Date
    Mar 2012
    Posts
    8
    huntsville, AR
    massey ferguson 90
    thanks for the help. Another ?, which valves are the intake and which valves are exhaust? Any more info regarding the propane 4 cylinder motor would really be appreciated and helpful. i haven't been able to find much about it.
    THANKS
  6. #6
    Member
    Join Date
    Aug 2011
    Posts
    42
    NE TENN - CENT FLA
    massey ferguson 255
    with out seeing it i will guess it is from front exh,int,int,exh,exh,int,int,exh. you can tell by looking at the exh manifold. if it is like i stated it will have one port at the front one large in the center and one at the rear and the intake will go between the exh ports. this is the most common.
  7. #7
    Join Date
    Mar 2012
    Posts
    164
    Akron, IN
    MF 85 diesel
    Set intake .016 and exhaust .018 hot.
  8. #8
    New Member
    Join Date
    Mar 2012
    Posts
    8
    huntsville, AR
    massey ferguson 90
    thanks for all the info, but i need more. can someone tell me about propane motors? For example, how much presure from the propane bottle does it take to start the engine? Does it matter how big the bottle is? Any info would be appreciated.
  9. #9
    Join Date
    Mar 2012
    Posts
    164
    Akron, IN
    MF 85 diesel
    As long as there is fuel in LP tank you will have pressure, but can vary greatly with temperature, 150-200 PSI on a hot day, as low as 30-50 PSI on a cold day. If regulator is working correctly LP carb/mixer will control fuel vapor. Best to start cold engine on vapor valve first, then turn on liquid valve when warmed up, turn vapor valve off when warm. Can run on vapor only but will not have full power when needed, may frost over tank as pressure drops when pulling hard on vapor valve. This applies to all tank sizes. Find a copy of owners manual, will explain best way to operate your model.
  10. #10
    New Member
    Join Date
    Mar 2012
    Posts
    8
    huntsville, AR
    massey ferguson 90
    Thanks so much for info. We have engine running!!! Of course now i have another problem. The PTO seal in the back is leaking. Can u give me any suggestions or info on repair or replacement?
Similar Threads
  1. Does Anyone Own A Massey Ferguson 590
    By bmcqueen23 in forum Massey Ferguson Owning/Operating
    Last Post: 04-14-2013, 01:01 AM
  2. Massey Ferguson
    By Travis_R in forum Massey Ferguson Owning/Operating
    Last Post: 07-08-2007, 06:32 PM
  3. Finally bought the Massey Ferguson GC2310
    By MEhorseFarm in forum Massey Ferguson Buying/Pricing
    Last Post: 04-19-2007, 10:10 PM
  4. Help identify my fathers Massey
    By Willl in forum Massey Ferguson Owning/Operating
    Last Post: 10-23-2006, 02:15 AM
  5. MAHINDRA vs. MASSEY FERGUSON
    By Travis_R in forum Mahindra Owning/Operating
    Last Post: 08-09-2004, 12:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
